Planting Hens and Chicks
Intro: Planting Hens and Chicks
Hens and chicks are hearty and an excellent plant for a new or beginning gardener. Most can handle temperatures down to -5 Fahrenheit, and can be used as a houseplant, outdoor plant in a pot or can be used as an outdoor ground cover.
Hens and Chicks are shaped like an artichoke with rosettes that vary in size and color, depending on the species they can be bright red, grey and purple, or green. Being they are succulent plants they have high light and low water requirements, since they are able to store water in their leaves.
You can find them as big as 12 inches around and as small as 2 inches at full maturity. Some are 'bearded' with fine or down like hairs and some will appear to be covered in spider webs, depending on what kind of Hens and Chicks you have.
They reproduce via branches or offshoots. As the rosette grows, it puts out shoots or stems, if these shoots get long enough to find soil, they will root and create new rosettes. The first rosette is the "hen", the stems or shoots are the "chicks".
STEP 1: To Plant Hens and Chicks You Will Need:
Your choice of succulent plants found in many Lawn and Garden Shops or just ask a friend who has some Hens for some chicks. I am using Golden Sedum here.
Any kind of planter a minimum of 4 6 inches deep or a sunny area in your yard.
Garden Charcoal
Potting Soil, specific to Citrus and Cactus
Garden Charcoal
STEP 2: Prepare Your Planter
I used my container gardening method https://www.instructables.com/id/Successful-Container-Gardening/ to get started, but this is a matter of choice and is not necessary with Hens and Chicks.
Start with a little garden bark in the bottom of the planter and a toilet paper core.
Add some Garden Charcoal.
Place dirt around the tube filling your pot to around one inch from the top.
Fill the tube with more garden bark and then add some gravel on top to aid in keeping the plant off of the soil to help avoid rotting.
STEP 3: Plant Your Chicks
Gently pull a chick from the container.
Brush away as much soil as possible exposing the root.
Press the chick into the prepared area near the edge and bury the entire root.
Continue until you are satisfied with your arrangement.
Use a soft paintbrush to clean dirt out of the rosettes.
STEP 4: Watering Tips
To Water, fill a sink or bucket with water and submerge the entire pot. Not covering the plant any more than you have to.
When air bubbles stop rising out of the pot remove it from the water and allow it to drain until all dripping stops.
Let your Hens and Chicks remain out of sunlight until the rosettes are totaly dry (otherwise they will burn).
STEP 5: Caring for Your Hens and Chicks
Remove chicks as the pot becomes overcrowded and remove any dead leaves
If your plant begins to look unhealthy the most common problem is due to too much watering. If the soil is soggy prepare a new planter with all fresh soil and transplant your Hens and Chicks.
Don't be concerned with fertilizing as you will probably burn the roots with it, when you are ready to transplant the chicks refresh the soil with a 50/50 blend of the original soil and the citrus and cactus potting soil.
Almost all hens and chicks will form a flower when they reach full maturity. After flowering it will then die.
The Hen will stop making chicks and a spike grow in middle of the rosette as she prepares for the end of her cycle of life.
40 Comments
Pearl 1 7 years ago
Can Hens & Chickens survive the Northern Nevada, aka Fernley, climate?
Cold/snow in winter, hot, 90-100 summer.
minnesotagirl71 7 years ago
I would think so. They survive winters in Minnesota and summers of 80s and 90s.
I have loads of hens and chicks that have been multiplying for close to 20 years. This year large areas of them have turned yellow. Does anyone know why that would be and what I can do about it? Thanks for any help.
bobm720 12 years ago
KathyF56 8 years ago
kat.hinkle1 9 years ago
Please what is the purpose of the toilet paper tube?
JohnMac 14 years ago
Aleesha_c 9 years ago
stayathomedad 11 years ago
I found the planters, pictured here, here at home, Are these inside or outside plants or both?
Any suggestions will be greatly appreciated.
Thanks in advance.
Respectfully,
stayathomedad
Rufustwo 9 years ago
Good info on hen and chicks. I have many of these and am just now making a succulent display in a large bowl with 2 smaller containers set inside,I need to purchase more plants to fill this and am wanting the other colored chicks,OR is there a way to make the green ones turn colors?????????? Will send photo when my Bowl is finished.thanks for info.
Rufustwo
bccf 10 years ago
My hen and chicks are growing tall and look more like roosters. I've tried just pinching off the tops, but that still looks bad. Any ideas what I should do to keep them short and full?
pkuhn1 12 years ago
please help. meanerthanilook@yahoo.com
diamar79 14 years ago
bluefly1215 13 years ago
container_gardener 14 years ago
Deewheat 14 years ago
im4tooele 14 years ago
hsmomof2 14 years ago
