Introduction: Plastic Bottle Self Extinguishing Ashtray
Two wrongs make a sorta right--recycle a plastic bottle as a smoke-catching, self extinguishing ashtray.
Step 1:
Start with a 1 liter plastic bottle
Step 2:
With your cutting tool of choice, cut the bottle slightly above the label all the way around.
Step 3:
Your two pieces should look like this.
Step 4:
Add about an inch of cat litter or sand to the bottom of the bottle.
Step 5:
Turn the top part of the bottle upside down and fit it snugly into the bottom part.
Step 6:
Using any wider household tape, add tape around the outer part of the bottle at the top leaving at least 1/2" extending over the top of the bottle. Fold this extended part of the tape over into the inside to enclose the seam.
Step 7:
You can cut 1 or more V shapes into the top edge to hold burning cigarettes.
Step 8:
Drop the burning cigarette butt through the bottle neck. (watch that you don't leave the burning part resting against the side of the bottle--it will melt a hole and ruin your creation).
The smoke is trapped in the bottle, and the reduced oxygen will extinguish the cigarette. I should mention that you shouldn't be either buying stuff in plastic bottles, or smoking. But just in case you do.
