Plague Doctor Mask
677,263
1,412
74
Introduction: Plague Doctor Mask
So after looking around online I decided I didn't quite like any of the plague doctor masks that I was seeing as far as tutorials, it all seemed like a lot of extra work for something that never turned out very clean.I decided to throw caution to the wind and just take elements of masks I've seen that I liked for inspiration and try and make one up on my own. I decided on a base of crafting foam, I've yet to see one made out of it which surprised me (maybe I wasn't looking in the right places) but it bends nicely and still has a firmness to it. So here's what I did if anyone is interested:
You'll need:
Crafting Foam sheet (x2, one for the mask and one for the straps for the back)
clear colored plastic binder divider
fabric of your choice (thinner/lighter the better, you'll be hand-stitching a lot)
wire gauge, stiff enough to hold a shape on it's own and not instantly bend
thread
black paint (forgot to picture, i used acrylic)
hot glue gun and sticks
scissors
needles of your choice (need to be durable and go through a lot)
any decor embellishments
paper and pen (to make the template)
something round to make the circles for the eyes and something straight to draw the lines
Step 1: Make a Template
using sheets of paper determine the size and shape you want your mask to have. The key elements are the left/right side panels, the bottom left/right panels, and the top panel (later you'll make the eye cutouts and head straps).
(attached are the scans of mine, the right panel is the same as the left, just face the flip side up and then they are symmetrical *also sorry for the poor lines, my scanner did not like me but I tried my best* originally cut out of computer paper so when I scanned it in I kept the same dimensions)
Step 2: Test Your Template
using tape try and test the shape, make sure it fits yourself or whoever will be using it comfortably
Step 3: Cut Out Your Foam
I was able to fit all of the template pieces (including eye cutouts, excluding straps) on one sheet. It goes a long way. (12x18 inch sheet)
Step 4: Fabric
Lay the foam onto the fabric, and outline in marker with an additional ~half inch margin around the pieces (enough to fold over). Cut out the fabric and fold over/hot glue the interior so the edges are also covered
Step 5: Assembling
Here you have two choices, you can dive into stitching or glue first. Gluing will make stitching a bit harder in the long run, but you get the reassurance everything fits in the right places. I personally glued first as this was my prototype but in the future if I make another I'm going to dive into stitching.
Step 6: Stitch the Seams
Start hand stitching! It's time consuming and depending on how much foam/hot glue/fabric is layered certain areas will be harder than others, but it's all doable (some will require a nice sturdy book to press the needle against to get it to go through all the layers), and some will cut through like it's just a cheese clothe. Focus on connecting pieces, the beak and the top. This is the connection time.
Step 7: Eyes!
For the eyes now we get to repeat the process! Take something round, (I used a roll of tape but it was too large and I cut it so much I really don't know what to recommend as far as the round size ratio but I threw in the final measurements for you if your going by my size choice), cut out the foam. Once you do that do the same with the fabric with the margins. When gluing the foam to fabric, it may help to cut little vertical slits (edge of fabric into the foam) in the fabric so it's easier to fold and glue.
Once the fabric is glued on, stitch the interior of the circle edge.
cut the plastic divider and hot glue to the interior
Then (if you want to glue first you can, I did, and) stitch the exterior of the circle onto the mask.
Step 8: Side Stitch and Hot Glue
Stitch the sides/edges of the entire piece, and cut/hot glue the wire (I did two circles of support) inside the beak
Step 9: Paint
My stitches weren't as dark as I'd like, so I took some black paint and darkened the area of the stitches to make them more apparent.
Step 10: Create a Strap and Embellish
A made two rectangles out of foam, did the fabric stitch paint process, and then did the same with the strap (I made it a one size strap). Attached it to the mask and added the embellishments (three metal studs on each side)
Step 11: And Done!
And we're done! Take photos and do with as you'd like!
(the interior I never cleaned up, no one but me will see the inside so I stopped there, but if you'd like to clean up the inside I'd just change the fabric to double over on the inside or create a cutout panel and glue it on).
Overall, ~7 hours, but I think next time now that I'm not making it up as I go I imagine ~5 hrs
Halloween Props Contest
First Prize in the
53 People Made This Project!
  • Microcontroller Contest
  • Crayons Challenge
    Crayons Challenge
  • Cheese Challenge
    Cheese Challenge
74 Comments
mrretinas
mrretinas
1 year ago
Looks fantastic! One small question how do you breathe once it’s on your face? I was thinking of putting eyelets along the bottom otherwise I reckon my child will suffocate.
PumpkinPatchPlagueDr
Reply 2 months ago
Do you not know how to add breathing holes? Just make them in the beak
AngelaE47
AngelaE47
Reply 1 year ago
This actually made me lol 🤣🤣🤣
'erm yeah, just a quick question, how do you actually breathe through this, as I don't want my child to suffocate' I was thinking the same thing XXX
Forester_The_Goblin
Very interesting, I also have an idea, as I've seen people make faux leather out of just foam sheets, I wonder how it would look without putting the fabric upon it and just using the foam textured and painted as leather, it would probably save a lot of time and be far easier to sew for beginners.
Gelsey456
Gelsey456
Question 1 year ago on Step 11
I didn't see in the instructions where the wire was used. Could anyone explain? Thank you!
9
PatternMeDaddy
PatternMeDaddy
2 years ago
Can anyone post an actual pattern? It would make this 10 times easyer
JimB273
JimB273
Reply 1 year ago
Yes......so I can make one for fun!!!! and to scare people
7
plaguepyramid
plaguepyramid
Reply 2 years ago
I used the pattern OP created and remade the pattern in Maya with a slightly longer beak. This is the outcome. I used it to make my own and it's coming out good so far. (face_resize_2 is the tip of the beak.) This pattern should be able to be used the same way as described in the tutorial, but if you'd like just the regular sized face pattern, let me know 👍
22
EmmaGardner1
EmmaGardner1
Question 2 years ago on Step 10
how d u download the template?
JimB273
JimB273
Answer 1 year ago
How can I download a usable template??
NicoleA101
NicoleA101
Question 2 years ago on Step 5
I covered the craft foam with fabric and hot glued it together, but I can't at all sew it, not even with a hand held sewing machine as it's way too thick. I pushed the needle as hard as I could and couldn't get it through even once. I'm a newbie so don't have many specialized tools to work with. Any tips?
salishsilver
salishsilver
Answer 2 years ago
You could get a craft awl and make holes to stitch through that way. Probably way too late, but that's what I do when working on projects like this. Just have to make sure the holes are where you want them. It can make things look a bit weird if they're not even. It can look handstitched, as it is.
Colleen Kitchen
Colleen Kitchen
Where do you get your foam?
elektradelight
elektradelight
Question 2 years ago on Step 4
how thick would you recommend the foam to be
Daniel0250
Daniel0250
2 years ago
Ya estamos armados contra el covid19
IMG_20200325_205904_051.jpgIMG_20200325_205904_066.jpgIMG-20200325-WA0010.jpgIMG-20200325-WA0011.jpgIMG-20200325-WA0012.jpg
4
Mitomon1
Mitomon1
2 years ago
This will be perfect for the pandemic!
CptFuture
CptFuture
2 years ago on Step 7
Thank you for the instructions! Simple, Succinct and Suave, here's a pic.
saladsalads
saladsalads
Tip 2 years ago
You can use felt instead, for me it was easier to find and worked just as well. Paint over it for better effect :D
ArkosB
ArkosB
Question 4 years ago
Personally, I found this very helpful. I did have some problems that I had to work around because I didn't know the exact measurements therefore,problems. I'm the end I made a crude paper mask that I intend to turn into something a little more sturdy. Still wearable. I was wanting to cosplay SCP-049. I guess my question is about the exact measurements.Also about the top piece. I couldn't figure out how to make it.
