Playstation Earrings
Intro: Playstation Earrings
GAMERS BEWARE! NO CONTROLLER IS SAFE!
One day you could be happily playing your games console then go to sleep and in the morning BAM! two of your buttons are gone and your friend has a new pair of earrings that look suspiciously like your missing buttons! *
I would love to say this Instructable came to me while I was sitting a top a mountain meditating on the meaning of life but I'll be honest it came to me while walking around my room looking for ways to use ninety earring findings. Alas that is not what this Instructables led me to. After making these and and my Lego Head Earrings I have decided to make small collection of earrings that are instantly noticeable and that set of a wide range of thoughts and memories about the past.
* I do not condone the stealing of controllers even to make my projects!
STEP 1: What You Will Need
2 Part Epoxy Glue- From a pound/dollar store
Clear Nail Varnish- Also from a pound/dollar store
Some means of cutting and filing plastic and removing screws- I used a exacto knife and a full size metal file but you could use a multi-tool as pictured.
Earring Findings- I use 4mm but anything up to around 8mm will work.
An Old Games Console Controller- Xbox, Playstation, Nintendo 64 etc.
STEP 2: Dismantling the Controller
The Clean Way (How I Did It)
Every part of this way is documented in the pictures.
Step 1- Remove the six screws from the back of the controller (I think The Hulk must have got community service for destroying the city at Sony tightening screws, as one took ages to budge)
Step 2-Remove the sneaky little screw in the circuit board that my screwdriver is pointing to in picture two
Step 3- Remove the circuit board and back and front leaving yourself with the triangle, circle, square and X buttons.
I've always wanted to have a kite that was controlled by analog sticks like the ones in the Playstation 2 controller but that's not my area of expertise and totally off subject. Back to the action.
The Messy Way
Step 1- Attack the controller with a hammer breaking it into pieces
Step 2- Take the above mentioned four buttons
It's your choice
STEP 3: Preparing the Buttons
How I Removed The Excess Plastic:
Step 1: Shave pieces of plastic off using your blade, like when you cant find a sharpener and sharpen a pencil with a knife, until you have about three mm of plastic left.
Step 2: File the piece down flat another mm until it is 2 mm thick
A Faster and Probably More Efficient Alternative:
Step 1: Use a hacksaw to cut the piece to 3mm
Step 2: File the piece down to a 2mm thickness
Once again totally your choice!
STEP 4: Varnishing
If you have quick dry nail varnish this will obviously be quicker for you.
My way of getting the buttons nice and shiny is five coats of varnish applied lightly.
IMPORTANT
It is crucial that the varnish drys properly between coats otherwise one coat will mix with the previous semi-dry coat and it will go streaky . I was told by a friend that if you press the back of your nail against the varnish and it leaves a mark it is not dry and this method seems to work.
If you are in a hurry two thin coats then one thick coat will occasionally give satisfactory results but I don't recommend it.
STEP 5: Attaching
Mix the two parts of the epoxy glue in equal measures. I prefer to dip the flat part of the the earring post into the glue but you could apply it using a toothpick or something like that.
Place the glued posts on the circular mark and leave to dry as shown in picture 2
Member mom123: suggested crazy glue for this part so you could try that!
STEP 6: The Finished Product
All that's left to do now is to thank you for your time and notify you that more jewelry will be coming up very soon.
Thank You
Ross
13 Comments
GloomyBearIsSick 11 years ago
nawipanama 11 years ago
The Science Guy 11 years ago
You could:
-Sand them down with a little drum sander like on a dremel
- File them down just with a regular file and some hardwork
-Melt them down too with the tip of a glue gun or with a heat gun but I wouldn't recommend it
-Cut them down roughly with a utility/ stanley knife then sand them to a nice finish
-Saw them using a hacksaw or fine toothed saw
I would recommend the first one but it depends on your resources
Good luck
Ross
tykal123 11 years ago
Also what kind of store would you be able to buy earring posts at?
I bought my earring posts with backs in a pack of 100 on eBay, you could also obtain them from most craft stores such as Hobbycraft at a considerably more expensive rate.
Here is the link to the earring posts I bought: http://www.ebay.co.uk/itm/100-6mm-Flat-Pad-Silver-Plated-Earring-Post-With-Backs-Stoppers-Findings-/300656853960?pt=UK_Crafts_JewelleryMaking_GL&hash=item46008b83c8
These are great value for money and are also good quality, just don't leave them lying on the floor, feet and earrings don't go well.
I thank you for viewing my Instructable and for subscribing. If you like earring making I have other earring Instructables you could look at.
Hope all goes well
Ross
mom123 11 years ago
How I did it was I put crazy glue on the thing and put some on the post and then stack it to the thing !
It worked great and as easy as 123 !
Pass on pleas !
Thanks
mrscoloradogal 12 years ago
The Science Guy 12 years ago
jessyratfink 12 years ago
I never thought to cut them down like that, but I did do a lot of sanding to make the back look nice. :)
