Plywood Cutting Board
Intro: Plywood Cutting Board
Tools Needed
-Table Saw
-Clamps
-Planer
-Slide Miter Saw
-Drum Sander (recommended)
-Palm Sander
STEP 1: Cut Plywood Strips
-Acquire 1/2" plywood and set the table saw at 1 1/4"
-Cut 18 strips as shown
STEP 2: Glue
Generously apply glue to each of the strips face and clamp them together like a sandwich.
STEP 3: Run Through Planer
-After the glue has dried, run the piece through the planer
-Plane until the piece is flat on both sides as shown
STEP 4: Square the Imperfect Edges
-Use a slide miter saw to square up each edge
-Try to cut as little material off as possible
STEP 5: Run Through Drum Sander
If available to you, run the piece through the drum sander to smooth the surface.
STEP 6: Round the Edges
-Trace around a round object on each edge to keep consistency
-Move to the disc sander to round the edges
-Sand down to pencil line
STEP 7: Cut Dado Cuts to for Visual Appeal
This step is optional
-Set up the the sled on the table saw as shown
-Set appropriate blade height to cut in 1/8"
-Cut 1" from the edge of the cutting board
STEP 8: Paint Dado Cuts
-Tape off each dado slot for accuracy
-Paint the inside edge of each dado cut for visual appeal
STEP 9: Sand Through the Grits
-Start at 80 grit sand paper and attach it to a vibrating palm sander
-Take your time sanding through the grits (80, 100, 120, 150, 180, 220, 240, 320, 400)
STEP 10: Finish With Tung Oil
-apply tung oil generously
-let it dry overnight and apply a second coat
-allow a week for the second coat to cure before use
10 Comments
JerryL1206 4 years ago
BronnieC 5 years ago
MarioH49 7 years ago
I have access to literally a boatload of plywood and this will be my next project. I don't think I'd use it in the kitchen, but I have a laser engraver and I'm wondering how laser etchings will look on this when it's finished. I think they should look amazing.
I've wanted to do some plaque shapes to then engrave with the names of player and coaches on my (gridiron/)football team and this could be the exact base I've needed. I wanted something that looked different, a bit rugged even, thanks for a great idea... As Old-n-Kranky said, this instructable is borderline brilliant with so many uses!
Old-n-Kranky 7 years ago
Great idea, I had never thought of doing something like this with plywood. Sorry though, but I agree with Yonatan24. Plywood is purely a manmade construct, with layer upon layer of veneer sandwiched together and bonded with industrial glue. I'm not sure what the impact would be of using this in the kitchen, but I don't think it would be very nice.
However, don't let any of these negative comments put you off. Your ingenuity in developing and creating this Instructable was borderline brilliant. I would never have thought of this.
VitaliyP6 7 years ago
If I cut the meat and small pieces of adhesive formed from scratch in the board can land on my food... is it safe?
Yonatan24 7 years ago
No.
fpobdoc 7 years ago
I would also be concerned about the grooves. They are so small that they will be difficult to clean.
IamGutter 7 years ago
I have to agree with skepticaljay on this. Great Instructable, and the plywood gives it a very unique look, but the chemicals used in making plywood are not conducive for food service.
skepticaljay 7 years ago
Swansong 7 years ago
That looks great :) I love the striping effect from the layers.
