Introduction: Plywood Knife
About: We're born, we make, and we die. So start making!
DO NOT DO ANYTHING DUMB WITH THIS AND IF YOU DO, YOU CAN NOT BLAME IT ON ME.
Step 1:
Materials
Ply wood (scraps will work)
Old knife (or new)
3 small nails (that fit in the hole where the pin held the knife went in)
Tools
Dremel
Drill
Jig saw
Step 2:
Take the blade out of its holder.
Step 3:
Cut out a card board tamplate, then cut out two from plywood.
Step 4:
Cut a groove in one piece of the plywood.
Step 5:
Drill a hole(I used a 5/64 inch bit) in the groove to hold the knife. Then clamp both together and drill a hole through the already drilled hole into the other piece of wood. Then nail them together.
Step 6:
Drill to other holes in the wood.
Step 7:
Take out the nail and take them apart. Then sand it till it fits snuggly in your hand. After that, nail them together.
Step 8:
If your nails stick out, use your dremel to cut off the ends.
Step 9:
If yor blade wiggles, put super glue on were the blade touches the wood.
