Plywood Reindeer
Intro: Plywood Reindeer
Intro
How about a big reindeer decoration for Christmas ?
It is 1.8m length and 1.7m heght in 100% scale.
8 feet x 7feet in 126% scale.
You can use both indoor or outdoors.
If you fold it in the barn during the off season, you can use it next year.
Materials
- Plywood or OSB (Print "patterns" in following scales) ... 2 boards @$10-20
[100%] t12mm x 900 x 1800 mm
[100%] t15/32 (≈ 11.91mm ) or 1/2 inch(≈ 12.7mm) x 3 x 6 feet
[126%] t19/32 inch x 4 x 8 feet (19/32 inch ≈ 15.08mm)
12mm x 126% = 15.12mm
[ 67%] t1/2inch x 2 x 4 feet (slit must be adjusted)
The original pattern size is for t12 × 900 x 1800 mm (About 3 x 6 feet)
Chose water resistant board for outdoor use and pain properly.
- Carbon Transfer Paper
... 2 sheets or more @$1 or less - Paint
(necessary for outdoor use) $10-20/deer - Copy Paper
(as large as you can print on your printer)
Total: $30-60 / deer
Working hours
Design: 2 weeks (You don't need this if you use patterns below)
Copy : 1 hour
Trace : 2~3 hours
Cut :2~3 hours
Paint :1 hour
Total: 6 - 8 hours (exclude design and shopping)
One day is enough to make. but might be exhausted nice.
Design is already done for you . Just make it ^_^
Buy me a coffee
If you could... supporting me , buy me a cup of coffee from following address. https://www.buymeacoffee.com/shink
Buy complete model (Japan only)
If you are in Japan,can buy completed products from here.
STEP 1: Print Patterns
1. Print PDF Pattern files for outline
- Use Acrobat reader for printout
- Use " Poster" in print menu. That will automatically print it on multiple pages
- set scale 100% for 900 x 1800mm board,126% for 4 x 8 feet. 67% for 2 x 4 feet.
2. Number it for layout.
3. Draw a 100mm grid ( same size of grid on printed paper) on plywood by pencil softer than B. You can clean it with eraser after cut.
4. Pin the pattern paper with carbon paper on the grid.
5. Trace with ballpoint pen .
Update (Dec/12/2019)
DXF file added for NC cutting.
I am happy if you make a lot and give it "free" to your company employee or neighborhood .
Please pay attention to CC license , especially "Non Commercial" terms.
STEP 2: Cut
Cut using a jigsaw.
It doesn't matter if the outer lines are cut slightly out of line. It is a wild animal.
The most important part is the slit to be combined with other boards.
Please cut carefully so that the width of 12㎜ slit comes out exactly.
I think that it is also good to make a jig from the unused part of the board ,and redraw the slit line according to the board width. Especially when using a board other than 12mm.
Please check clearance when you cut first slit, and adjust. Cut other slits as same as first one.
Sand the cutting edge # 180-240 with paper before assemble, if you prefer to do.
Do NOT round cut surface of slit , that make wobble structure. Sand there flat.
Safety precautions
The most important thing is not to cut any part of your body.
There is only one point. Do not take your finger, hand or others in the direction of the blade.
And watch your children keep safe.
Be sure to wear goggles. Sometimes jigsaw blades break and fly.
So you need some spare blade. I used 3 blades for one set.
And wear mask.
When cutting small parts, it is easier to cut them into rough parts first.
If the board hangs down and pinches the blade, or if the material is going to break under its own weight, escape from the cutting line and cut off the material.
STEP 3: Assembly and Setting
Just assemble like puzzle. Pay attention to the orientation of Antlers.
There is no need to glue.
If it is too tight, adjust it with a file or sandpaper #80-160.
File flat as possible for avoid wobble.
If you set a reindeer on outdoors, take measures to prevent it from falling.
Use four camping pegs on the ground and tie the legs down them.
Please paint it with your favorite color. Clear is nice too.
And add a Outdoor christmas lights (Amazon)(Aliexpress)
STEP 4: Postscript
[3D print version]
You can get small 3d print version from here
https://www.thingiverse.com/thing:3213535
This is made for verifying design by myself before wood working.
[3D print sleigh]
https://www.thingiverse.com/thing:3926757
[Plywood sleigh]
This is just a drawings. I don't have made yet and will not make this year 2019.
Please try it before me , if you want.
Two kids or slim adult can ride it ,but can not slide on snow ^_^.
It was designed seriously, but please try with your own responsibility for strength or other problems. Please check for safety very careful and add metal fittings if needed.
It is difficult to use trace technic , because slit pitch must be precise than reindeer. For precision cut, you had better to re-measure and redraw the lines with straight ruler after trace.
Board size is t18 x 1230 x 2440 mm , almost same as 23/32inch ( ≈ 18.26mm) x 4 x 8 feet.
3 boards ( A layout x1 , B layout x 2)
52 Comments
TrevorAH 3 months ago
Astrajosh63 1 year ago
Great reindeer hats off to you.
I had the reindeer made on a cnc router a few years ago and display it outside my house and people love it. I was wondering if you had the dxf file for the sleigh?
For people not able to see the pdf files it because your most likely viewing this in mobile mode switch to desktop mode and you'll see the pdf's or dxf files.
Slaven 1 year ago
shinkdifferent 1 year ago
Nath 2 years ago
je n'arrive pas à imprimer toutes les pages des planches mais seulement 1 ... Pourquoi et comment puis-je faire svp
shinkdifferent 2 years ago
https://www.pcastuces.com/pratique/astuchttps://www.pcastuces.com/pratique/astuces/3851.htm
Autumn1969 2 years ago
Is there any chance of that happening? I was hoping to make this for the kids in the apartment building to enjoy. I wanted to add it to the decorations that l am putting out on December 1st.
Can anyone help me figure out this?
All you want is here. You can download PDF free too.
Please read again all instruction, and "made it" comment.
perfo 4 years ago
May I make a suggestion?
Instead of transferring the pattern on to the wood, simple stick the paper to the wood with water soluble glue. Cut the shapes out then using water and a stiff brush wash off the paper. If you are going to paint it anyway then maybe you don't even need to remove the paper ?
shinkdifferent 4 years ago
If it is a plywood for outdoor use, it will be no problem if it is quickly wiped and dry after washing (May be ).
perfo 4 years ago
https://www.amazon.co.uk/SprayMount-YP208060506-Adhesive-Spray-Transparent/dp/B000J68HBO/ref=asc_df_B000J68HBO/?tag=googshopuk-21&linkCode=df0&hvadid=262024380476&hvpos=1o1&hvnetw=g&hvrand=7814422438779741391&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=20343&hvtargid=pla-436109169041&psc=1
The above is an amazon link to it. Basically you can get glue that would hold your pattern to the ply nice and firmly but the patter can be pealed off afterwards. I've got some so I'll give it a bash when my ply turns up..
Verga 3 years ago
shinkdifferent 3 years ago
Please make your town a raindeer town!
I think it's very valuable to show the students that the teacher moves his hands and makes something for himself.
People who can make something will change the world better, right?
gwilki 3 years ago
After resizing your components so that I could cut it all out of a 24" x 24" panel, I resized all the slots to match the thickness of my material.
It worked great! Thank you very much for posting this. I will,of course, credit you with the design when I post my reindeer on the CNC forum.
And wow, you have your own cnc that can cut 24inch.
gwilki 3 years ago
https://forum.sienci.com/t/reindeer-games-slot-ani...
I've just finished a .dxf of your sled, too. It will be much smaller than your's, but uses your design.
Mallaround 3 years ago
I really looking forward to see the photos of that you made one.
And I googled now and see that, female reindeer has antlers too . and male antlers drops in winter season. wow : )
Skkear 4 years ago
