Introduction: Pocket Rifle (Knex Pistol)
Description: This is a high power knex pistol that will fit into your average front pocket. It has very good accuracy over a long range but shoots high so you need to aim low. it is approximately the same size as KILLERK's pistol but is (debatebly) more powerful and can fire any size rod (yellow rods work best) and can even fire twigs from trees, laugh out loud. The gun is very sturdy and the firing pin is difficult to remove from the back so that it is less likely to be accidentally pulled out during cocking. It is single shot, the trigger rotates clockwise to fire. It uses one cut part for the trigger (half a green rod) and duct tape on the firing rod pull. It uses firing elastics, a trigger elastic, and three elastics to keep three white rods in for extra stability.
You need a k'nex hinge to make this gun.
Step 1: Build
1: Build 2 of these.
2: Attach with 8 white rods as shown.
3: Make this.
4: Attach by connecting a white rod on either end as shown.
5: Add 3 white rods as shown. Pull an elastic from one end of the rod, over the top of the barrel, to the other end of the rod. Now each elastic keeps the rods from falling out of the holes. Refer to picture 16.
6: Make this (the green rod has been cut in half).
7: This is what the fully assembled trigger will look like when it is in the gun.
8: Add the trigger. Attach elastic as shown.
9: Make this.
10: Attach as noted.
11: Hold a gray connector pointing up like this.
12: Attach as noted.
13: Make this.
14: Add duct tape as shown.
15: Insert into gun. Add firing elastics as shown.
3: Make this.
9: Make this.
13: Make this.
Step 2: Firing
1: Lightly pull back on the trigger as shown while pulling the firing rod back.
2,3: Load a rod.
4: Push the trigger down and forward (clockwise) with your thumb to fire.
2,3: Load a rod.
