Poisoned Apple
2,894
34
9
Introduction: Poisoned Apple
About: I started woodworking with my grandfather as a young boy. I continued woodworking through high school, and started woodturning after seeing a turned project in a friends shop. Some of my fondest memories are w…
The Poisoned Apple is an iconic symbol from the classic fairytale from the Brothers Grimm. I turned this one on a lathe, and dyed it red with Transfast wood dye. To add an extra element of spooky, I used a Lichtenberg figure wood burner to burn lines in it. It's 4" tall and 3 1/2" in diameter, and made out of Maple.
Tools and Supplies used:
Lathe
Sandpaper
Bandsaw
Spindle sander
Drill Press
Easy Rougher
Easy Finisher
Parting Tool
Roughing Gouge
Clear Lacquer
Lichtenberg burner http://www.conestogaworks.com/
Transfast dye
Step 1: Wood Choice
I picked out a piece of Maple 4" x 5 1/2" with a bark enclosure to simulate a bite mark for the apple. I think picking the right piece of wood can really make the project sometimes.
Step 2: Shaping the Apple
I marked center on the wood, and put it between centers on the lathe. Use a roughing gouge to true the piece up, and a bowl gouge to shape the apple. I used a Easy rougher to put a tenon on one end, this will be used to remount the piece in the chuck for sanding and parting off.
Step 3: Lichtenburg Burning
Lichtenberg figures are branching tree-like patterns that are created by the passage of a high voltage discharge along the surface. I really wanted to give it that bad apple look :) Here's a link to how this LICHTENBERG FIGURE WOOD BURNER works. Video
Safety notice: The output voltage and current (12,000 volts
@ 35 mA) from this burner can cause serious burn, injury, or death if these instructions and safety precautions are not followed. The safe use of this burner is entirely the responsibility of the purchaser. If you have any electronic implant, consult your doctor before using. If you do not agree with this, do not use it and immediately return the burner for a full refund.
Step 4: Making the Stem
I used a small piece of Lacewood for the stem. I drew it out with a pencil 1 1/4" by 1/4" and cut it out on the bandsaw. Using a spindle sander, I rounded over the corners and finished it with an oil finish.
Step 5: Dye
I put on three coats of Transfast scarlet red wood dye with a paint brush. Let each coat dry for about an hour before reapplying.
Step 6: Finish
After burning and the dye, it really opened up the grain so it took about 15 coats to get it to shine. I used a gloss lacquer finish.
I hope you enjoyed this project.
Halloween Decor Contest 2016
Be the First to Share
    • Reclaimed Materials Contest
    • Cookie Speed Challenge
    • 3D Printed Student Design Challenge
    9 Comments
    Carl Jacobson
    Carl Jacobson
    Reply 5 years ago
    Thank you very much!
    clschmidt14
    clschmidt14
    5 years ago
    That is awesome- I love it!
    Carl Jacobson
    Carl Jacobson
    Reply 5 years ago
    mlawing
    mlawing
    5 years ago
    Wild stuff, Carl!
    seamster
    seamster
    5 years ago
    This is so cool. Perfect use for that neat chunk of wood. Nice work as usual Carl!
    Carl Jacobson
    Carl Jacobson
    Reply 5 years ago
    Thank you very much Sam!
