Polarity Tester
Intro: Polarity Tester
This tester can be used to check the polarity of any power source, and is therefore very useful when installing automotive equipment, alarm systems or anything else you can think of. Because this circuit is so simple and cheap, even frying one with an over voltage is not a big deal.
STEP 1:
There are many polarity tester available in market like one above but it is just a waste of parts.
STEP 2: BOM(Bill of Materials)
BOM(Bill Of Materials)
1. green led
2. red led
3. 330 ohm resistor(optional)
4. soldering iron
5. solder
STEP 3: Soldering Led
solder positive terminal of green led to negitive terminal of red led and negitive terminal of green led to positive terminal of red led
STEP 4: Soldering Resistor(optional)
solder 330 ohm resistor to led in series to prevent led from burning
STEP 5: Enclosure
LUC VOLDERS made enclosure for this in tinkercad
http://lucstechpage.weebly.com/polarity-tester.html
3 Comments
Luc Volders 9 years ago
Not only did I made it. I also designed an enclosure for it in Tinkercad and provide you with the STL files on my webpage:
http://lucstechpage.weebly.com/polarity-tester.htm...
Thanks for this. A simple but very usefull design.
Luc
Hey guys,
Simple but so obvious that I missed it:
You can use this design also as a cable tester. Just put the polarity tester in series with a battery and a cable or wires you want to test. Simple but effective !!!
Look at my website for some examples:
http://lucstechpage.weebly.com/wiretester.html
amberrayh 9 years ago
Thanks! This would be very useful!
