Polymer Clay Pug Tutorial
Intro: Polymer Clay Pug Tutorial
How to make a pug out of polymer clay. You can use it to make a bead, earrings, a magnet for your fridge...or anything else you would like. The design can be scaled down or made larger to fit your project's needs. You also can change the colors to match your dog.
STEP 1: What You Need
The photo shows amounts of clay that will be used.
You will need beige, brown, black and white colored polymer clay (tiny glass holeless beads are optional). Also, I reinforce each added piece of clay with liquid polymer clay.
STEP 2:
The larges ball of beige clay is flattened. This will be the head.
STEP 3:
Next grab one of the larger balls of brown clay. Shape into a triangle. This will be the snout.
STEP 4:
Place snout on bottom, center of the beige head piece.
STEP 5:
Next, shape two of the smaller (about half the snout amount) balls of brown clay into teardrop shapes. These will be the eye spots.
STEP 6:
Place with pointed side up on both sides of the top of the snout.
STEP 7:
Now, we will make the eyebrows. Take the small balls of beige (the same amount as the eye spots), and roll into tiny snakes, tapering at the ends.
STEP 8:
Fold snakes in half pinching ends lightly together.
STEP 9:
Place the eyebrows on the top part of the head over the eye spots with rounded ends touching in the center.
STEP 10:
Take two more of the larger balls of brown (same amount as snout). Shape into triangles. These will be the ears.
STEP 11:
Place on top of head, but a little off to the sides.
STEP 12:
Back view of ears.
STEP 13:
Now, the nose. Grab the small ball of black (about a quarter the size of the eye spots). Roll into a ball, slightly oval shaped.
STEP 14:
Place nose on the top part of the snout.
STEP 15:
Roll tiny balls of white (about half the size of nose) to make the eye balls. Place on the center of each brown eye spot and flatten.
STEP 16:
Add a tiny dot of black clay or tiny black holeless beads to the center of each white eyeball.
STEP 17:
Take a needle tool or needle and press into the center, bottom half of the snout.
STEP 18:
Side view of finished bead.
Poke hole in desired position.
Bake according to directions on clay package.
STEP 19: Finished!
Here is what your finished pug should look like.
© 2009-2011 threemoonbabies / Marjorie Dalgarn, All rights reserved.You may use this tutorial to make jewelry for sale. If you do so, please link back to Marjorie Dalgarn ( http://3moonbabies.etsy.com or http://livingwiththreemoonbabies.blogspot.com) in the item description.
8 Comments
achace 1 year ago
Cats_Eye 9 years ago
PUGGLY, WUGGLY!!!
poofrabbit 12 years ago
yngla 12 years ago
susanrm 12 years ago
ThreeMoonBabies 12 years ago
wilgubeast 12 years ago
