Poor's Man Mill
Intro: Poor's Man Mill
Usually the people that do your beer, or homebrewers, use the manual mill to grind the malt.Some others use the a drilling machine attached to the mill axis. Works fine but over time eventually damage your drilling machine.
STEP 1: New Motor ?
I found a old motor, saved from a old washing machine with 1/2 Hp and running in 127Vac.
STEP 2: The Mill
This is a standard grain mill, with the handle removed, and attached a pulley with 150mm diameter.
STEP 3: Wooden Stand
With an old wooden stand for CPU, I decided to adapt and fix the mill, including a new wooden support.
STEP 4: Cut and Paste
For this I cut and pasted a new piece of wood, trying to leave with a nice appearance.
STEP 5: Appearance
The quality was not very good in appearance, but is very functional and fixed.
STEP 6: Motor->Add()
The next step was buy a "VA" belt in necessary length and mount the motor using a metal plate to fix the motor in the wood.
STEP 7: Enjoy the Mill
The relation between pulleys wasn't calculated, but I imagine around 120 rpm in the mill axis.
STEP 8: First Test
The belt is loose, if a crash occurs, it simply escapes, preventing motor burn.
3 Comments
kelms1 9 years ago
baecker03 9 years ago
fatdestruction 9 years ago
Yes yes, it was a prototype with old things I had at home.The final cost was approximately USD 10.00 (pulley, belt and screws).
A steel frame would be ideal, but the project can become expensive.
Thank you
