Portable Bluetooth Speaker 2X3W
Intro: Portable Bluetooth Speaker 2X3W
STEP 1: Prepare the Case
You can use all the types of cases because the speakers, powerbank and module are very small,i have choose to do my own wood case.
Drill the holes for the speakers for the front and cut the pieces for the case, i had to trim the front/up sides of the wood case to be abble to fit the speakers.
STEP 2: Front Part
Place the speakers in the correct position and secure them with small wood pieces glued with wood glue, when its dry remove the speakers and glue them using contact glue and hot glue
STEP 3: The Switch
Mark the position of the switch and cut it carefully, i connected directly the switch to the power bank positive usb cable (red one), the switch controls the power output of the powerbank.
I have also apply some clear lacquer to protect and give a better look to the wood.
STEP 4: The Electronics
its very simple , follow the schematic, to recharge the power bank connect an mini usb extension on the back of the case, isolate all the exposed wiring and solders with shrink tube and hot glue, do an hole on the back cover to expose the mini usb cable to recharge the powerbank.
STEP 5: It Works !!
It as a nice sound, the battery should last plenty of hours, once again learning a little bit more in every project.
Tank you for watching.
(Sound test in the video in the beggining of this instructable)
13 Comments
MANUM65 5 years ago
can we use a different bluetooth module?(
Sound King 2 Channels 3W Pam8403 Class D Audio Amplifier Board 5V Usb Power)D-TeK 5 years ago
yes, it will work
JoseM258 6 years ago
Hi, Just received the amp. What's the name of the male connector you use for the speaker to the board? Thank you!
D-TeK 6 years ago
I used this one :
https://goo.gl/keC4tB
it fits ;)
Thanks! I'll be doing something like this soon.
psargaco 6 years ago
In the video you drill two tiny holes over both the top corners of the switch. Why?
D-TeK 6 years ago
Hello, i was trying to "capture" the led indicator lights from the powerbank using two pieces of clear plastic
DanC145 6 years ago
Can you use slightly bigger speakers? like 52mm? thanks
D-TeK 6 years ago
I used 52mm speakers in this project, you can use speakers a little bit larger if you want.
ThatMouse 6 years ago
I'm wondering if anyone has links to source some good quality speakers. I'd like to make something similar, but I want it to sound as bright as Klipsch speakers. I know speaker makers tend to make their own, so perhaps there is no market for quality "bare" speakers.
D-TeK 6 years ago
Tank you, i tried to create some contrast between the different pieces.
ejonesy 6 years ago
Does there have to be a certain voltage for the switch or can there be any?
D-TeK 6 years ago
