Portable Metal Detector
Intro: Portable Metal Detector
This instructable is just another way to make one cheap and easy portable Metal Detector, using one of the 50 555's schemes that is available in the internet, in this book: http://www.talkingelectronics.com/projects/50%20-...
I've simply made my own portable metal detector with some little improvements, like a 3mm green LED for signalling when the device is searching and a potentiometer to adjust the volume of the searching task.
STEP 1: Material
The list of components to make a metal detector like this is:
1 - NE555
1 - 1mH coil (I've reduced the value from 10mH to save some copper assembling my own coil, because less inductance => less wire spins)
2 - 2.2uF electrolyte Capacitors
1 - 10uF electrolyte Capacitor
1 - 47K resistor
1 - 8R speaker
1 - pressure button switch SPST NO
1 - 9V battery
Optional components:
1 - green LED
1 - 330R resistor
1 - 10K potentiometer
STEP 2: To Construct the Coil
The bigger difficulty of the metal detectors, is the coil. I don't know if we can find some coils, with the specific value of mH that we need.
Therefore I've made my own coil with an empty round package of pringles, which has 7cm of diameter.
Considering the value of 1mH, I've just had to simulate the coil lenght and the number of spins, to start the construction of the coil.
For those simulations, I've used this Air cored inductor calculator: http://www.m0ukd.com/Calculators/air_core_inductor...
I've used a wire of 0,3mm and I've reached the result of 121 spins, with a lenght of 39mm for my coil.
I've cut off a piece with the 39mm, from the empty package of pringles and I've made the 121 spins of the 0,3mm copper wire, making the coil that we can see in the picture.
The calculator refers that the value is valid to values of lenght > 0,4 * diameter, and it has an accuracy of 1%. In that case, I've made a coil with 1mH, +/- 1%.
STEP 3: Schematic
Like I've refered in the introduction, I've used the 555's scheme, making some changes, adding a signalling LED and a way to adjust the volume of sound in the speaker.
Well in this step we can see the small differences between the 2 schemes, in the 2 pictures.
STEP 4: Assemble the Circuit in a Breadboard
The first assembly of the circuit must be done in a breadboard, to test if it works and to take the first conclusions about the range of detection and so...
I don't have any picture of my circuit assembled in the breadboard to share. :(
STEP 5: Final Mounting
After be certain of the full functionality of the circuit in the breadboard, we're able to mount it in a PCB, or in pre-pierced board, like I did.
The image shows the device already mounted, inside one empty old toothpaste case, with the circuit hot-glued inside, the coil hot-glued on it's top and the cap of the potentiometer on.
Now, I have my own portable metal detector! I just need to push the button and start searching... :)
7 Comments
Alanmelb 4 years ago
mati ur rehman 8 years ago
i want to make a metal detector using tda0161, when the detector detects the metal from a specific distance the buzzer sounds but as the metal comes near and near the buzzer sound increases!!
so anyone guide me for this
i want to use this with arduino
jaimealmeida 8 years ago
When I made my metal detector, I didn't know about the existance of the tda0161. Thank you for the information. Looks like you just have to connect the output pin of tda0161 (pin 3) to some input pin of the arduino and you'll get what you want!
MohamedE93 8 years ago
How to improve the range ? I mean how to make it in high range ?
This circuit changes output frequency when a piece of metal is close to the magnet. In this case, you can change the frequency of the input, changing the value of the 4k7 resistor, or the value of the capacitors C1 and C2, but I don't know how it can increase the range of the detection - you'll have to test it before...
jaimealmeida 9 years ago
No, I didn't have any success with my searchs of metal yet. I must inform you that this detector has a very small range of detection - it only causes some kind of distortion, in the sound of the speaker, when it is in the presence of a big amount of metal and very close to it... It must be improved, changing the values of capacitors C1 and C2 and the value of the resistor R1 also, in a way to improve the frequence of the oscillator, to make it more sensitive to distortions.
craftclarity 9 years ago
Nicely done. Have you found any doubloons or pieces of eight yet?
