Introduction: Portable Nutella Phone Charger
This is a Nutella phone charger!
Step 1: How to Make the Portable Nutella Phone Charger
No, this is not a normal jar of Nutella. This is a portable phone charger!
Step 2: What Do You Need?
The only 4 things you need are:
1. An empty Nutella jar
2. Brown clay
3. Tin foil
4. A portable charger
Step 3: Covering the Insides of the Nutella Jar
Stick the brown clay onto the walls of the empty Nutella jar. Making sure that there is enough space for your portable charger. The clay has to be about 0,5cm-1cm thick.
Step 4: Placing the Portable Charger
Place your portable charger vertically in the Nutella jar. The charging hole has to be facing upwards.
Step 5: Placing the Tin Foil
Crumble up your tin foil, and place it around the portable charger. Tip: Use a long pointy object, like the back of a paint brush, to place the tin foil.
Step 6: Covering the Top
With your left over clay, cover the top of the Nutella jar. But make sure that you are able to screw the lid on.
Step 7: Dry and Test
Let it dry and test it out!
