Dual USB Charger With Switching Regulator
Intro: Dual USB Charger With Switching Regulator
It takes an input voltage from 8 to 16 volts and can run from anything from a 9 volt battery to a car battery.
It has 2 USB ports and easily charges 2 power hungry devices at once.
STEP 1: Parts & Tools
Parts
LM2678 - 5V Switching Regulator
STPS10L25D Schottky Diode
22µH 5A 15mΩ Inductor
470µF 16V Electrolytic Capacitor
120µF 16V Electrolytic Capacitor
100nF Film Capacitor
10nF Ceramic Capacitor
Dual Type A USB Jack
5.5 x 2.5 mm Barrel Jack
5.5 x 2.5 mm Barrel Plug
3x2x1" Project Enclousure
Slide Switch
Protoboard or PCB
LED & Resistor (Optional)
Tools
Soldering Iron
Dremel
Wire Cutters
Needle Nose Pliers
X-Acto Knife
Screw Driver
STEP 2: Build the Circuit
A PCB would be best for this circuit (although I used protoboard)
I cut the circuit board down to fit the box with a Dremel.
Heat doesn't seem to be a problem.
The diode runs cool, and the regulator runs about 50°C with a 2A load.
The regulator has built in over current and thermal protection.
The LM2678 can supply up to 5 amps but the circuit here has been optimized for 0.5 to 2 Amps.
STEP 3: Put It in the Case
Cut out a slot for the USB ports and the power jack.
Cut out a hole for the slide switch.
I used a Dremel and X-Acto knife to make the holes.
I mounted the board with hot glue. The switch and jack are also glued in place.
I put a 3 mm blue LED in the lid.
STEP 4: Finish It Up
Touch up the screws with a sharpie.
Put together a power cord.
Check the output voltage, it should be very close to 5 volts.
The USB standard specifies 4.75 - 5.25 volts
This charger can run off a battery pack, AC adapter, or the 12v power port in the car.
It will be most efficient at 9 -12 volts. And it will draw about 1 Amp at full load.
STEP 5: Using the Charger
The charger can run at full power for over 2 hours off 8 AA rechargeable batteries, or 8 hours charging 1 device at 500mA.
40 Comments
umairahmadh 6 years ago
Can You help me find the issue?
chinocrix 6 years ago
This setting will not work with apple devices with lightning ports
discovery20720 6 years ago
Am working on a mobile charging kiosk and i need to build a quick charge in a ratio of 1% to 0.5 sec.Is this one going to work for us
rocketman221 6 years ago
This charger was not made for quick charging phones. It provides up to 2 amps at 5 volts like a typical wall charger.
If you use a higher current inductor and put a heatsink on the regulator, you can run it up to 5 amps.
CYBERJ_21 7 years ago
can i use 12v car battery as my input??
rocketman221 7 years ago
Yes, it will run from car battery just fine. You should put a 2 amp fuse in series with it to be safe though.
JieE2 8 years ago
Sir, can you tell me it can provide the fix 2A 5V power? im trying to do a project which need fix current between 1A to 2A with 5Vdc power supply.
rocketman221 8 years ago
This power supply is constant voltage, there is no current limiting other than an overload shutdown in the 6 to 8 amp range.
musharaf raza 8 years ago
can u tell me what amp of input through this devise can give me the out put 2amp
The input current depends on the input voltage. With a 12v input and 2A load it draws 930mA. At a lower voltage it will draw more current, at a higher voltage it will draw less.
kotosif 9 years ago
Does this instructable work with modern smartphones? Such as S3 or Iphone?
vashteusen 9 years ago
rocketman221 9 years ago
There are some tricks you may have to do with the data lines to get modern devices to charge. Most devices will work with the data lines floating. Every thing I have tried worked fine.
Some devices need a 200 ohm resistor across the data lines. Apple devices need voltage dividers to provide 2.8v on d+ and 2v on d-.
aswinmp 9 years ago
hi,
I have 12V 3A power supply. Will this circuit work, if I give 12V 3A as input.
RoMaNs.2012.H 9 years ago
Please Dude help i have a problem the regulator is not available in my country can you sugestt another one ?? thanks :)
An LM2676 (5V fixed output) should work. It's almost identical, but the maximum output current is 3A instead of 5A.
jerry mughal 9 years ago
LM2678T and STPS10L25D is not available......................................plz tell me alternate lm and diode that i can use
The diode is back in stock now, and the regulator is available here.
yooooo1089 9 years ago
Can I connect three 3.7 LiPo 1000mah batteries at the input.
And how much times, this circuit can charge a 1500mah battery within what time.
Yes, three lithium cells will power it just fine. It should provide almost two full charges. The charging time depends on the charging circuit in your device. It should be the same as when it's plugged into the usb port on a computer.
