Trivet From Recycled Wine Corks
Intro: Trivet From Recycled Wine Corks
Materials :
*1 piece of wood (eg. oak) of ~ 80 * 3.5 * 1 cm (32" * 1.5" * 3/8")
* 64 wine-corks
* wood-glue (preferable waterproof)
* wood oil
* sandpaper
Tools :
* Saw, preferable a jig saw
* Cutter knife
Time : takes about a day to complete : mainly because you need to glue a row of corks, and then wait for the glue to dry.
* 64 wine-corks
* wood oil
* sandpaper
Tools :
* Cutter knife
STEP 1: Make a Mold
when assembling this pot holder, the corks will be 'squeezed' into the frame. In order to be able to glue everything together (and then keep it that way for a couple of hours) I decided to make a mold.
It is very simple : cut a square hole out of a piece of leftover wood, eg an MDF board. If you want to make a lot of pot holders, you can cut several mold-holes out of the same board.
STEP 2: Cut Outsides - Assemble Frame
The inside dimensions of the wooden frame need to be precise : if it is too small the corks won't fit in, if it is too large, they will not stay in a nice square pattern.
After experimenting, I've found out that the inside needs to measure 170 mm (6.7"). I guess that corks are about the same size all over the world, but to be absolutely sure I recommend that you double-check this : squeeze 8 corks in a row, and measure the lenght.
If you want to make smaller (eg 6*6 corks) or larger (eg 10*10 corks) pot holders, you need to adjust the numbers based upon this measurement.
In fact I think that a set of 3 pot holders, 6*6, 8*8 and 10*10 would make a very nice set :-)
If you have experience with cutting wood, you could make a miter joint, which will look more professional.
Then apply glue to the 4 pieces, place them into the mold : this will ensure that the frame is flat and square. Let it dry a couple of hours
STEP 3: Adding the Corks
Make sure the glue of the frame is sufficiently dry : when squeezing in the corks, they will apply pressure onto the frame, and if the bonds break you will have to start all over again...
Take 8 corks and trim their length with the cutter knife if they would be longer then the frame's height. Warning : cutting a cork is not that easy, and so you need to be careful. I found that this works best : cut the cork as deep as you can, then roll the cork so it rotates about 45 degrees and cut again, repeat this until it is cut completely.
Then put the 8 corks into the frame : keep the cut side up (so they all align with their top side at the bottom)
In case there is too much pressure to fit the corks, you can slice off a bit of one or more corks that seem to be too big..
Then apply glue to corks : glue to where they touch the frame, and glue to where they touch each other.
Use a leftover pice of wood to temporary keep the corks in place. Check the pressure, alignment. Let it dry
Remark : some glue may/will drip through, so be carefull about the surface you are assembling this on...
Wood glue can easily be removed with water as long as it has not dried completely.
STEP 4: Finishing
Remove the pot holder from the mold.
Remove exces of glue by cutting it away with the cutter knife
Sandpaper the outside frame until it is smooth.
Apply wood oil and let it dry. I often use wood oil from IKEA, which is good, cheap and doesn't smell.
17 Comments
SparkySolar 9 years ago
Thank you for your nice Instructable.
Rima
m2grzegorczyk 11 years ago
slamonella 11 years ago
strooom 11 years ago
CatalinRO 11 years ago
Good luck !
sgarner1 11 years ago
andro000 11 years ago
tencentdress 11 years ago
One could hang this or a perhaps larger one on the wall and use as a traditional cork board.
Great idea ! You would need a lot of corks : eg for a 60 * 40 cm you would need ~527 corks, but know that most restaurants have a surplus of corks they don't know what to do with.. So you could give them a box, write your phone-nmbr on it and then wait for a call when the box is full.
scooterdad 11 years ago
It can take quite high temperatures and I have seen some people using it to fix parts in alcohol stoves so will probably be quite good in the heat tolerance area, Worth a try I think
tbrugada 11 years ago
RainDog07 11 years ago
