Introduction: Power Up ANYTHING With Old Cell Phone Chargers.
Green Electronics Challenge
Gadget Hacking and Accessories Contest
7,722
77
3 Comments
8 years ago on Introduction
Actually you should not use the pot at all. It is inefficient, cannot supply much current, and does not regulate. Use a regulator or just stick to rated voltage. A pot should generally be used only for a fixed, know load, and after the revelant equations for power and voltage are checked.
8 years ago
You might find a 50ohm rather than 50kohm pot more effective and give wider control stability but as you stated a linear regulator would be far superior
Correcto! i changed it. Thank you.
