Prank: the Mummy's Finger
Intro: Prank: the Mummy's Finger
With April Fool's day just around the corner, it's time to revive those great pranks from childhood. This one scared me silly when I was about 10 years old.
I'll teach you to make a small, very inexpensive "Mummy's Finger". As you show it around, you make up some patter about how mummies never really die if their tomb is defiled. In another variation, you mention that your dad (or mom) works in an emergency room, and last night someone lost a finger in a horrible accident. You casually ask, "Ya wanna see it?"
Then you dare* one of the marks to touch the finger. Of course, just before he does, the finger moves!
The audience figures out it's your finger about 5 seconds later, laughs nervously, then starts dragging others over so they're not the only ones fooled. Best of all, the gadget is small enough to put in a backpack or coat pocket.
- Note that using a double-dog dare or triple dare is overkill and considered bad form.
STEP 1: Gather Supplies
You will need a small covered box, about 2" x 3"; an Altoids tin will work, but is a little harder to use. A cardboard box about the size of a deck of cards is ideal.
If the inside and outside of the box are not plain, you may want to either spray paint them or cover them with Contac paper (adhesive backed vinyl). For the mummy story, you want something that looks ornate, to distract the mark. For the ER story, it shouldn't look nice.
You'll also need craft or white glue and a large handful of cotton balls, or a 3" x 3" piece of felt, velvet or other thick cloth.
Finally, you can use a bit of color - a little red and gray water-based paint - to "age" the finger.
STEP 2: Assemble the Box
Take the box and cut a hole in the bottom. It should be about 1/3 of the way down the long edge, and centered on the short edge. The hole should be just large enough to put your index finger through comfortably. In my case, I drew around a nickel, then used an Xacto to cut the cardboard. If you're using an Altoids tin, you can use a set of tin snips if you can find one small enough. Be sure to sand the sharp edges, and use electrical tape or duct tape to cover them.
Glue the cotton balls or cloth in the box. If using cloth, put it in loosely, with wrinkles or padding underneath. You want to camouflage the hole. I found that putting a drop of glue on the cotton ball worked better than smearing the inside of the with glue.
STEP 3: The Result
When the glue is dry, it's time to practice.
The box will sit in the palm of your weak hand.
Place your index finger through the hole. Arrange the lining to hide the hole and base of your finger. Move your pointer finger towards the (missing) index finger to hide the gap. You can use the lid or lining to hide the pointer's gap. Practice opening the box and showing it around without moving your finger.
Work on your patter - find a story, tell it quickly, spring the surprise.
9 Comments
admin 16 years ago
sysadmn 16 years ago
admin 16 years ago
bluediomond 9 years ago
Heywasup 15 years ago
mwwdesign 15 years ago
Heywasup 16 years ago
KronoNaut 16 years ago
GorillazMiko 16 years ago
