Preserve Quality Paintbushes Forever. Drip-dry. Built-in Handle. Easy Clean-up.
6,634
45
5
Introduction: Preserve Quality Paintbushes Forever. Drip-dry. Built-in Handle. Easy Clean-up.
About: A restless creative. Builder of things sheet metal, wood and web.
Clean, dry and keep quality paintbrushes for a life-time.
Soak and rinse a paintbrush with no mess.
Drip-dry paintbrush vertically with a small rubber clamp attached to the paintbrush handle.
Made from an empty gallon milk container.
Can also use empty detergent containers for handheld paint container.
Step 1: You Need:
Plastic gallon milk container
Scissors or a box cutter
Marker
Small rubber clamp
Step 2: Mark Outline on Container for Cutting
1. Draw a line down the mouth of the container to neck of the container (at the top-point of the outline shape).
2. Draw outline shape above (similar to shape of a house)
Step 3: Cut Outline on Container
Cut outline.
Step 4: Cut Slit in Mouth of Container
Cut a line in the mouth of countainer down to the point of the outline shape.
Step 5: Clean Paintbrushes Sized Up to 4 Inches
Clean paintbrush sized up to 4 inches.
Step 6: Soak, Clean and Rinse Paintbrush
Fill the container with enough clean water to cover the dirty bristles.
Soak, clean and rinse dirty paintbrush.
Step 7: Easy-dry Paintbrush
Raise paintbrush and use rubber clamp to vertically hold the handle above the mouth of the container.
Vertical drip-dry is the best method to preserve life of paintbrush bristles.
Be the First to Share
    • One Board Contest
      One Board Contest
    • Anything Goes Contest 2021
    • Knitting and Crochet Speed Challenge
    5 Comments
    ledzep567
    ledzep567
    14 years ago on Introduction
    could this be applied to artists paintbrushes?
    ahead
    ahead
    Reply 14 years ago on Introduction
    Yes. The application works for smaller artists paintbrushes also. Replace the gallon jug with a smaller container (soft drink can, etc) No need to cut small containers because artists paintbrushes are small enough to place through the container opening into the clean water. Replace the clamp with a clothespin to elevate and hold small paintbrush.
    Maxx1
    Maxx1
    Real slick. Now I just need to find a stoer that sells empty jugs...lol
