Introduction: Press-fit Construction Kit
This Instructable is for a press-fit construction kit of Kurama from Naruto TV Tokyo anime.
You can cut out the pieces on a laser cutter using any material you'd like (I used plywood) and start construction your own Kurama shapes!
Step 1: Cut Out the Pieces on the Laser Cutter
I created a CAD model of the kit in Fusion360. The CAD files, as well as exported DXF files are included in the instructable. Use whichever file works for your laser cutter. All is adjusted for a plywood of 3mm wide.
