Printable Tilt-Shift Lens Adapter
Intro: Printable Tilt-Shift Lens Adapter
The results is a simple, cheap, lite, and durable adapter designed to fit a micro 4/3 Panasonic GF1 to Nikon e-series mount. All files are up on thingaverse and 123D gallery under creative commons, so you can download, edit, and remix to fit your needs. Be advised that to have the best results you need to use a micro 4/3 camera with a standard 35mm lens. I really think this is just the beginning for printable adaptors and hopefully the community will take the idea and create deviations for all different kinds of camera/lens combination.
STEP 1: What You Need + How It Works
The things you'll need for this project are pretty simple the only difficult part is selecting a proper camera/lens combo, which your can find more information on here.
- DSLR Body - This will help you get the appropriate measurements for creating the adaptor and also help you in selecting the right lens. For this tutorial I’ll be using a Panasonic GF1 micro 4/3 camera.
- 35mm/Medium/Large format Lens - This depends on the type of camera body you have. 35mm and Medium format lens can be found on eBay pretty cheap, and the size lens you're looking for will depend on the type of camera you’re using. For guide-on camera body lens combinations check out this guide. However, you'll get the best results using a lens that is design for a larger format camera then you currently have. more about this here. Example: Micro 4/3 camera with a 35mm type lens or Canon Rebel body with a medium format lens type. For this project I’ll be using a Nikon series E 50mm 1.8 which I picked up on eBay for less than $30.
- Calipers - Used to take measurements for the lens and camera for 3D model.
- 3D printer or Access to one - While it’s easy to print this off on your own printer at home, if you don’t have a printer you still have options. Look for a local hacker/maker space in your area using hackerspaces.org/map if nothing is close or they don’t have access to a 3D printer you can upload your project files to ponoko.com, and have your part mailed to you. I use them a lot for laser cut projects and have never had any issues, great service.
- 3D modeling program - http://www.123dapp.com/ (PC only) or http://sketchup.google.com/ (mac + PC)
see more of their DIY tips at http://www.youtube.com/user/indymogul
STEP 2: Take Measurements
We need 3 basic measurements before we can create a 3D model.
Camera Mount (adapter base)
Measures the lens that came with your camera (see image below for details on this measurement). Be sure to first measure the diameter excluding the three tabs. To do this place your calipers just inside two of the tabs and write down the nubmer. Then grab the lens that came with your camera and measure the small tabs Lenght x Weight x Height of one tab and then the distance to the next tab. It may help to sketch this out on paper. You might be able to find some lens measurements on this chart or you can see if an model exists in Google’s 3D warehouse.
Lens Mount (Lens you'll attach to the adapter)
Again follow the images below to take measurements of lens that you'll be attaching to your adapter. Depending on how secure you want your lens to attach depends on the details of this measurement. I was able to get away with a simple measurement of the diameter of the Nikon e mount and was able to make sure the 3D print would be a simple press fit. (it does not lock in place, it simply presses in place instead)
Focal Distance
Once you have selected your lens it’s time to figure out which distance it needs to be away from your camera sensor to make clear images.
Warning: Always be aware that removing your lens exposes your sensor to dust which could stick to your sensor and mess things up. So, be very careful with this next part and try to be in a room with little to no air movement i.e. fans, windows, a/c.
Remove your existing lens from your camera body, then hold up the body and newly purchased lens until the image comes into focus (see images below). This is by no means an exact science but here are some time saving tips. Open your aperture on your lens all the way. In this case I opened mine to 1.8. Use a tripod so you can use your free hand to adjust or measure the final distance once things look in focus. You can also use a toilet paper roll during this step to help judge distance by holding the roll as a makeshift temporary adaptor, slowing cutting off sections of the roll to make it shorter and shorter until you find the correct distance. Once you have a pretty good idea of the distance from body mount to the lens, write it down and head to the computer to draw things up.
Degree of tilt
This is up for experimentation but my current model is using somewhere between a 5 and 20 degree tilt. I seem to get the best results and most range with a 10-12 degree tilt, so try that a starting point. Here is a guide which will help you establish the perfect tilt.
Focal Distance
Degree of tilt
STEP 3: Create 3D Model
Feel free to download and modify my existing model, which can save you some time. However, I’ll also walk you through how I created this model based off the measurements we took in the previous steps. Before getting started with your first 3D model, it is good to get a grasp on some of the consideration and limitations of 3D printing. Ponoko has a great post on this topic here. A big consideration to keep in mind is that overhangs of more than 45 degrees will require a support structure which equals more printing material. Below you'll see the video of me working on this model in skechup, I've only been working in sketchup for a few weeks so if you got some pointer leave a comment below, try to keep it constructive.
Here are the basics steps in sketchup (I'll post a video soon)
- work in mm
- Circle from center Radius
- offset inside by 2mm
- delete center
- divided offset by 6
- top view
- offset 3 tabs 1.5mm byond outter ring
- Line tool connect tabs to ring (l) use esc to end line
- iso view
- highlight all reverse faces
- extrude tabs 2mm
- extrude circle 5mm
- select all right click group
- draw new circle on face
- offset 2mm and extrude 10mm
- select top face and rotate tool
- view left face
- rotate 10 degrees
- measure inner diameter
- highlight top again and scale till dia meets lens dia
- highlight all group and save as .stl using this extenuation
STEP 4: Print and Test
Once the file is ready to print, make sure everything is ready to go. Once your print completes give it a good cleaning to remove any loose strings, dust, ozozy bumps, or anything that could potentially fall off and ruin your lens or camera sensor. I like to use a utility knife to clean up the print and then blow it off with and air compressor.
Attach your adapter to your lens and then to the camera. While attaching to the lens, ensure that it is a snug fit that will hold up to wind and the great outdoors. If it is loose on the lens or the adaptor mount make small adjustments with a knife to remove it and use super glue or tape to hold up parts that are too loose. Make sure things are not sticky or wet when you try to reattach them. If something’s way off, re-measure and make the required adjustments to your 3D model and reprint. This is part of the fun, I mean your freaking manufacturing at home how cool is that!!! To add a good miniature effect to your photographs, shoot subjects from a high angle . It creates the illusion of looking down at a miniature model.
STEP 5: Resources
About Tilt-Shift
http://www.cambridgeincolour.com/tutorials/tilt-shift-lenses2.htm
https://vimeo.com/videoschool/lesson/104/tilt-shift
http://cow.mooh.org/projects/tiltshift/
https://www.instructables.com/id/DIY-Tilt-Shift-DSLR-Camera-Lens/
http://blog.makezine.com/2009/09/15/weekend-project-tilt-shift-photogra/
https://www.instructables.com/id/How-to-build-a-tilt-shift-lens/
http://www.youtube.com/watch?v=0HRYlJUwzYA
29 Comments
sgrant5 11 years ago
Nice work!
JoeMurphy 11 years ago
fritsjan 11 years ago
When I have some time I will try to make an adapter for a sony nex 5n.
chimera15 11 years ago
siouxsette 11 years ago
but please explain to me how is it a Tilt-SHIFT adapter, as there is no shifting adjustment?!?
Or to be more precise no adjustment whatsoever!
As there is no shift, forget architectural photography, etc. and the tilting beeing fixed, you cant adjust your focal plane, so the tilt is useless if you want to carefully compose your frame AND control apparent depth of field, be it for 'creative' portraits, packaging shots, products shots, scenery..
Apart for allowing you to participate in the fad of
"hey, it looks like a model train scenery" for everything else, This could be known as 'The utterly useless cone of garbage, with adaptey bits in the ends" But certainly not as a Tilt-Shift Adapter...
The other toy T-S adapters geared towards funny photography are way better:
You cant really shoot serious crap with them, but for so called creative photography, they give you some control on the effect you produce!
This one doesn't!
You really should call it a fixed tilt adapter, as it it what it is...
mnpazan 11 years ago
The base idea is still a great one though, and you're absolutely right that once the idea's out there anyone can run with it to make the real thing, so I'm still very appreciative, rather than vitriolic like Siouxsette. I just feel calling this tilt shift is at best a wee bit of a tease/chain-yank for people who already know what tilt shift is, and at worst completely misrepresenting what tilt shift is and what it's actually used for to people who haven't heard of it before.
noomsi 11 years ago
I'd love one for my G3 but unfortunately I'm in the uK.
jsousa2 11 years ago
It gives me chills to see your camera sensor exposed for so long >_>
A very nice project, some sort of mechanical join would be more useful for at least a tilt movement, I wonder if a not overly complex system is possible.
Good job, you have my vote!
RightShoe 11 years ago
Do you think to sell them? I would love to buy one if possible.
If it is possible, do you do Canon mounts too? Thank you :)
philpp 11 years ago
I have been looking at these and you are right the cost heaps.
I'm in Australia though :(
urant 11 years ago
I've just got a new 3/4 camera, and due to lens costs....well, you know how it is, it's just the thing to get the old hamster in the skull working!
I've got an old point and shoot camera with great glass, and I'm starting to toy around with the idea of gutting it from the old camera and adapting it to the new 3/4 mount.
Any Ideas?
griffinity 11 years ago
exadore 11 years ago
