Private Web Serving With the Raspberry Pi
Intro: Private Web Serving With the Raspberry Pi
You might be serving-up a lot more then you think you are! Do you know who is accessing your web server?
There are many ways of running a web server in a Linux environment, so to keep this Instructable a relatively reasonable length, I will focus on the common L.A.M.P.(Linux.Apache.MySQL.PHP.) implementation.
I explain searching your web server logs, setting-up typical access lists: blacklists, whitelists, and a combination of the two. I will also share with you my web interface for working with the .htaccess files remotely. Finally, we will look at an open-source firewall.
The following article assumes you have a Raspberry Pi 3 or equivalent, and installed L.A.M.P. Excellent article for getting started and RaspberryPi.org’s installing LAMP.
Image Credits: http://www.usanetwork.com/mrrobot
STEP 1: Keep Your Pi Updated!
sudo rpi-update
The command will automatically update the Raspberry Pi’s firmware and then ask for a reboot. If your Pi is already up-to-date, then you can continue with:
sudo apt-get update sudo apt-get upgrade
Now, you’ve got the latest and greatest firmware and software!!
STEP 2: Pi Passwords
Ideally, we would disable the default pi account, at the very least, set the default password for your pi account. Another major in-security is that most users have SSH (Secure Socket sHell) and VNC (Virtual Networking Computer) enabled so that they can remote into their machines. I don’t recommend allowing access outside of your network when running a publicly exposed web server.
STEP 3: Getting Online
You have several devices connected to your WiFi router, so how can you tell the outside where you are serving-up Raspberry Pi? Let’s get familiar with our router’s advanced settings in your router manufacturer’s configuration tool. Most home networks use one of these common IP addresses for their gateway to the Internet:
You will need to login to your router’s configuration tool. The username and password should have been assigned at the time of setup. First, we need to reserve an IP address for our Raspberry Pi to use on a regular basis. Typically, the router will have a DHCP (Dynamic Host Configuration Protocol) Settings section, List and Bindings, etc. The Raspberry Pi and all other devices on your LAN should be listed here. Hopefully, your router will have a somewhat intuitive interface that will make sense as to how to assign an IP address to a device or MAC address. If all else fails, consult your manufacturer’s instructions.
The default port for web requests is 80. You can leave the default unless your Internet Service Provider doesn’t allow port 80. Next step in your router’s configuration is to have the router forward all incoming requests on port 80 to the Raspberry Pi. Typically referred to as, Port Forwarding or Port Range Forwarding. You will want to associate the Raspberry Pi’s IP address so that it will receive all incoming requests on port 80 or whatever port you find most appropriate. The most secure web server is one that is not connected to the Internet ;-) Second to that, we should limit the access in our apache conf file to allow ONLY our IP and those known to us. You could also allow Telnet, FTP, SSH, VNC, etc but I do not recommend unless you are familiar with the security risks associated with such services.
STEP 4: Get Yourself a Domain Name
http://www.YOUR_CUSTOM_DOMAIN.ddns.net
Check for the DDNS ( Dynamic Domain Name Service ) Setting in your Router’s advanced configuration settings. Most routers will support one or more of the following, http://www.dyn.com, http://www.noip.com, many others search Google for “Dynamic DNS”. The service will offer the ability to register a domain name to associate with the Dynamic IP address that is assigned to you by your Internet Service Provider. Typically, your router or a software plugin that you download and install will update the Dynamic DNS service’s database when your assigned IP address changes.
STEP 5: Security Through Obscurity
https://en.wikipedia.org/wiki/Security_through_obs...
We often rely on our security being through some sort of obscurity. “If they don’t know about it, they can’t use it to get in.” Common household door locks only have so many combinations, yet we can rely on the lock of our front doors because we know that a thief would have to try every combination or break-the-door-down. However, on the Internet, who is watching your front door, so a thief cannot try every combination? Fortunately, our web-server has an access.log file that is automatically updated and archived for us. Let’s start there and see if anyone has left their “footprints” on your web server.
STEP 6: Log Diving
cd /var/log/apache2/ zcat access.log* | awk '{print $1}' | sort -n | uniq -c | sort -nr | head -20
The output should be a list with two columns, one containing the number of entries counted, and the second column is the IP address associated with each web request made. The easiest way to get the most information from a reverse IP lookup is by using the following command:
curl ipinfo.io/REPLACE.WITH.IP.ADDRESS.TO.LOOKUP
Rather than rely on an external web service, you can do some digging after you install some tools that are not included by default with the Pi:
sudo apt-get install geoip-bin geoiplookup IP.ADDRESS
Here is a good article on using geoiplookup. Even more advanced digging not included by default with the Pi:
sudo apt-get install dnsutils dig -x IP.ADDRESS
Does the location seem suspicious? Try grepping for the activity, the zgrep command includes the compressed files:
zgrep 'IP.ADDRESS' access.log* -1
By looking at the web requests that were made from the IP address, you can determine whether the activity is suspicious. Typically, you will find that these IP addresses are from bots looking for vulnerabilities in your security. You can manually block IP addresses to your blacklist or you can just deny all and allow select IP addresses. If you haven’t already, you’ll want to install and setup a firewall.
STEP 7: Apache Web Server
If you are serving web content world-wide then you’ll eventually want to adopt some sort of blacklist, or exclusion list, where you can keep specific IP addresses from accessing your server. However, if you want to tighten-down your security and only allow a select few access then you’ll need to make some changes.
cd /etc/apache2 sudo cp apache2.conf apache2.conf.bak
sudo vi apache2.conf
OR
sudo nano apache2.conf
Travel down the file until you reach this section that allows everyone access to your web server from the outside:
<Directory /var/www/> Options Indexes FollowSymLinks AllowOverride None Require all granted </Directory>
The AllowOverride directive is set to None meaning we will not be using an .htaccess file to override these settings. The next directive, Require is set to all granted, meaning allow anyone access.
Please note: I have found a significant number of bot requests in my log files, snooping for those of Us using phpmyadmin, be sure to limit access:
<Directory /usr/share/phpmyadmin/> Order Deny, Allow Deny from All # localhost Allow from 127.0.0.1 # Local-Area Network Allow from 192.168.0 </Directory>
Next, we can add a directory that we want to protect:
<Directory /var/www/html/hydroMazing/> Options Indexes FollowSymLinks AllowOverride All </Directory>
The AllowOverride directive is set to All meaning we will be using an .htaccess file to override these settings. We will provide the Require directive in our .htaccess file inside the directory we specified, in this case, “/var/www/html/hydroMazing/”
# AccessFileName: The name of the file to look for in each directory # for additional configuration directives. See also the AllowOverride # directive. AccessFileName .htaccess
You could change the name of the .htaccess file here to something harder to guess. Keep the dot at the beginning because it means hidden file. Use your imagination!
Now you can use an .htaccess file as your whitelist, or inclusion list:
To create a .htaccess ( or whatever you’ve named it ) file:
cd /var/www/html/mydirectory/
sudo vi .htaccess
OR
sudo nano .htaccess
# Allow access to localhost Require ip 127.0.0.1 # Allow access to my cell phone Require ip 98.97.34.23
Second entry is an example, change it to your IP address, or the IP address that your web server logged.
Save and close the file. You can add additional access as desired.
STEP 8: Make Everyone Use the Front Door
First, let's force anyone visiting our web server to use the front door
OR
Travel down the file until you reach this section where you can add redirects for 404 and 405 errors:
... # AccessFileName: The name of the file to look for in each directory # for additional configuration directives. See also the AllowOverride # directive. AccessFileName .htaccess ErrorDocument 404 / ErrorDocument 405 / ...
Save and close file.
Setup Access Listscd /var/www/html/
sudo vi .htaccess # localhost Require ip 127.0.0.1
Save and Close file.
Repeat for your admin directory
cd /var/www/html/admin/
STEP 9: Web Interface for Allowing Access
I'm sharing with you my simple web interface that I made for my hydroMazing Smart Garden System.
I wrote the basic interface using PHP to read and write files giving the user the ability to add or delete IP addresses from their .htaccess files.
Download the file and extract to your downloads directory and then copy them to your web server's base directory:
sudo cp -R /home/pi/downloads/*.php /var/www/html/
Change permissions:
sudo chmod -R www-data:www-data /var/www/html/*
sudo chown -R 755 /var/www/html/*.phpWait! Not so fast!
We should protect the username and password with an SSL connection.
https://hallard.me/enable-ssl-for-apache-server-in-5-minutes/
STEP 10: Build a Wall
Install the open-source firewall builder
Pop open a terminal from your Raspberry Pi’s desktop and type the following:
sudo apt-get install fwbuilder
After the installation has completed, you will have a new option under the Menu/Internet option from your desktop for the firewall builder GUI.
Add a new firewall and name it the same as your server.
Select the “web server” template to load default rules. Note that the default rules restrict your server from accessing the outside Internet. In order to allow access, you’ll need to add a rule. The easiest way to add a rule is to copy an existing rule that is similar to your needs.
STEP 11: Compile and Install
We can build our firewall through this interface, but we won’t be able to install it because we won’t have sufficient permissions to write to the file system. Enter the following at a terminal window’s command line assuming you named your server the same as your DDNS name:
sudo mkdir /etc/fw
sudo touch /etc/fw/servername.ddns.net.fw
sudo chmod 777 /etc/fw/servername.ddns.net.fw
Now, you should be able to use the firewall builder program to compile and install the firewall. You can either restart the apache web server or simply reboot.
Thank you for taking the time to read my Instructable!please follow me and learn much more at http://www.hydroMazing.com
2 Comments
catfishlee 7 years ago
Hydroponics will grow amazing plants however, it's not sustainable. It's expensive for all the synthetic fertilizers and not environmentally friendly or wise in my opinion.
An alternative might be Aquaponics or even simpler, forgo the fish and go with a Bioponics system for real sustainability!
Good work on a very informative and thought provoking project.
Jake
bitsandbots 7 years ago
I agree with you that hydroponics can be expensive, for all of the synthetic fertilizers that you speak of, which is why I advocate for as many organic solutions (pun intended!) as possible:
https://www.instructables.com/id/Compost-Tea-for-Hydroponics-and-More/
However, I strongly believe that most people should start with hydroponics before adventuring into Aquaponics, which requires much of the same equipment anyway, but with the care of fish and balancing the bio.
