Programing an Attiny With Arduino IDE
Introduction: Programing an Attiny With Arduino IDE
About: I'm a maker who love to build new things. I mostly dabble in Arduinos, Raspberry Pi's and paper crafts.
Attinys are an excellent way to shrink your Arduino project. I recently tried to follow this great instruction from the High-Low Tech website, but it looks like it is out of date. They have some tutorials and if you don't have an ATtiny programmer follow this tutorial. This instructable is how to program an Attiny on Arduino 1.0.6
Step 1: Download the Files
Go ahead and download this folder from the High-Low Tech website. Now go to your applications folder, and right click on Arduino then select Open Package Contents.
Step 2: Add the Files
Now navigate to the hardware folder. Go to Content >> Resources >> Java >> Hardware. Go head and drag the ATtiny folder, which is in the folder that you downloaded in the last step, and place it in this hardware folder.
Step 3: Blink Blink
Go ahead and open up Arduino and go to File >> Examples >> Basics >> Blink. Change 13 to 0. Your program should look like this...
void setup() {
pinMode(0, OUTPUT);
void loop() {
digitalWrite(0, HIGH);
delay(1000);
digitalWrite(0, LOW);
delay(1000);
Now we need to change the board so go to Tools >> Boards >> ATtiny 85 (internal 8 MHz clock). If your ATtiny doesn't have the bootloader go ahead and click Tools >> Burn Bootloader. Now you can upload your program. (You may have to change your programmer by going to Tools >> Programmer >> USBtinyISP)
Formlabs Contest
Formlabs Contest
Be the First to Share
    • One Board Contest
      One Board Contest
    • Jewelry Challenge
      Jewelry Challenge
    • New Year, New Skill Student Design Challenge
    6 Comments
    IraM1
    IraM1
    6 years ago on Introduction
    Nothing works… :( With Arduino IDE 1.6.3 show package contents you can get to the hardware by: Contents >> Java >> Hardware. And this is where I put the attiny folder but it doesn't work. This a different path than you show ("Resources" seams to lead nowhere). I first tried Sparkfuns instructions, "make a folder called hardware within your Arduino Sketchbook directory". That didn't work either. The IDE works great with my UNO…
    Any ideas??? Mac OSX 10.8.5
    Thanks
    peterfoxflick
    peterfoxflick
    Reply 6 years ago on Introduction
    In order to get it to work with the 1.6.3 IDE you need to add a folder.
    Right now inside the attiny folder looks like attiny >> boards.txt, variants. You need to add a avr folder between them. Change it to be attiny >> avr >> boards.txt, variants. I hope this fixes the problem, let me know if it still doesn't work.
    IraM1
    IraM1
    I've been using Arduino IDE 1.0.6 with the Tiny Programmer because I still can't get 1.6.3 to work. Your last comments did work fine though, thanks. The board can be selected and the programmer can be selected, but there is no option under port that seems to coincide with the Tiny Programmer. In 1.0.6 I can select the right port and upload fine but not in 1.6.3? In 1.0.6 the ports start with "dev/tty." and "dev/cu." but in 1.6.3 the "dev/tty." selections are not available. Why is it not accessible? Sorry to bother you again but I'm tired of jumping back and forth between versions! :(
    Thanks again for the help!
