Proof of Concept Valveless Air Canon
Intro: Proof of Concept Valveless Air Canon
For the longest time I have been intrigued with canons of all sorts. Actually to boil it down I love loud explosive anythings. The louder the better. If it goes boom and you feel it in your chest I fall in love. Because of this fascination and the relative inexpensive of PVC I have invested my time in developing an air release for pneumatic devices that is essentially valveless. You won't have to fork out the extra cash for a butterfly valve or attempt to modify a sprinkler valve. While this proof of concept will reduce cost in your pneumatic devices it does have it's draw backs. I will explain throughout this ible. As this is my first ible please bear with me if I make a few mistakes.
For this ible I will be making a small scale model. There is a 3in by roughly 18in air reservoir which transitions down to a 1in by roughly 24in barrel. * I apologize for the gee by guesses, I actually made this PoC a few months ago and put it into storage when I moved. I am actually looking at pictures that I took while making it to write this. *
By reading this ible, you the reader, assume any and all responsibility in your attempts to recreate or modify this design.
STEP 1: Parts Needed
Since were dealing with PVC aside from the obvious items needed (PVC Cleaner/Primer, PVC Glue, Safety Precautions) you will need the following:
18in x 3in PVC Pipe
3in PVC Cap
3in PVC Coupler
3in to 2in PVC Reducer
2in PVC Coupler
2in to in PVC Reducer
1in PVC Coupler (Despite the picture showing two)
1in PVC Cap (Despite the picture showing none)
24in x 1in PVC Pipe
1in O-Ring
Grease of any kind
Considering the price of a butterfly valve this is a relatively cost effective way to create a pneumatic device.
18in x 3in PVC Pipe
3in PVC Cap
3in PVC Coupler
2in PVC Coupler
24in x 1in PVC Pipe
1in O-Ring
Grease of any kind
STEP 2: Preparing the Parts
The two couplers are going to have to be slightly modified as well as the 2in to 1in reducer. If you look inside of couplers you'll notice a lip along the inside. This lip prevents your PVC from sliding to far in either direction. However, we want to get rid of that. I had some scour pads at home, so that's what I used. Most people can find some form of scour pads around their kitchen sinks. If you don't happen to have a scour pad a round file will work as well.
You'll notice in the first picture the inside lip is already missing. The second picture actually shows how I ended up removing the lip. Originally I started with a file but that made the inside too jagged. I ended up slowly rotating a scour pad by hand but figured I needed a faster way. You'll know you're ready to continue when the 1in PVC pipe slides through both couplers with little effort. You don't want it to just drop right through, make sure there is a little give yet but not much.
STEP 3: Air Intake
I chose just to use a bike stem valve for putting air into the reservoir. Drill a hole into the cap just large enough to fit the valve stem. Approx. 3/8in bit. Although I suggest you check before you drill. After drilled you may want to put some thread compound around the thread. This will prevent air from leaking.
WARNING MAKE SURE ALL YOU PRESSURE TEST ALL PARTS AT LOW PSI BEFORE PUSHING IT TO THE MAX. IF THERE IS A LEAK YOU ENDANGER YOURSELF AND MORE IMPORTANTLY YOUR HEARING. WHEN PRESSURE TESTING LISTEN FOR A SMALL LEAK SOUND. IF YOU HEAR IT PUT THE PNEUMATIC DEVICE DOWN AND GET A DECENT WAYS AWAY FROM IT. WAIT TILL THE AIR HAS FULLY LEAKED. THEN PUT VERY LITTLE PRESSURE IN IT AND LOOK FOR THE LEAK. IF IT CAN BE PATCHED WITH A LITTLE EXTRA GLUE DO SO. OTHERWISE START OVER. I WAS HOSPITALIZE WITH EAR DAMAGE WHEN I HAD AN PNEUMATIC DEVICE EXPLODE IN MY HANDS!
The first picture shows the valve stem in place. The second show the thread compound I used.
STEP 4: Priming and Glueing and Assemblyy
Reservoir
Prime and glue the 3in coupler to the 3in pipe then prime and glue the 3in reducer as shown in picture 1.
Custom PVC Fitting
Take the 1in coupler prime and glue the bottom of it to the top of the 2in to 1in reducer. Take the 2in coupler prime and glue the bottom as well as the inside and force it over the 1in coupler you glued to the 2in to 1in reducer. Push it all the way down. Pictures 2,3,4, and 5 show you what the final product looks like.
The 2in coupler over the 1in coupler is just for extra strength. While it isn't necessary, I highly suggest it. All in all this custom PVC piece is roughly 3 inches in length.
Barrel
Now prime and glue the 1in cap to the 1in pipe. Measure 1.5in from the cap and drill a hole straight through the 1in pipe. Take your o-ring and slide it down the 1in pipe till it meets the 1in cap.
"Assembly Part 1"
Slide the 1in pipe through the custom PVC fitting. See Picture 6 and 7. I put a little grease around the o-rings to help air from leaking out.
"Assembly Part 2"
Prime and glue the custom PVC fitting and attach it to the 3in to 2in reducer. Finally Prime and glue the 3in cap the the opposite side of the 3in pipe. Allow several hours to fully cure. See picture 8 for fully assembled PoC.
Custom PVC Fitting
Barrel
"Assembly Part 1"
"Assembly Part 2"
STEP 5: How to Use
Attach air hose to valve stem and allow air to leak into reservoir. Grab the barrel and pull out till it can't go any further. The o-ring and grease will form a seal against the custom PVC fitting allowing air to fill in the tank. To release the pressure pull back on the barrel. Air from the reservoir will escape through the holes drilled in the PVC barrel.
Now I promised to tell you the downside to this PoC. Once there is pressure in the reservoir it tends to get pretty difficult to pull the barrel back to release the pressure. Although if cost is an issue this is a definite win.
Possibilities for this PoC would be to shot projectiles into the air a quick release drop valve. Let your mind go wild. ENJOY!
14 Comments
admin 15 years ago
PointyOintment 13 years ago
aaon 14 years ago
drhoff 14 years ago
carl87gt 14 years ago
the mechanical engineer 14 years ago
tjk94 14 years ago
aaon 14 years ago
jomodad 15 years ago
aaon 14 years ago
imthatguy1125 15 years ago
aaon 15 years ago
aaon 15 years ago
