Introduction: Pumpkin Candle
Finished project
Step 1: Loading in the Pumpkin
Import the pumpkin model from here: https://www.thingiverse.com/thing:1836056
Step 2: Putting Words Into the Pumpkin
Place the text in order so it says "Trick" on the top, "or" in the middle, and "Treat" on the bottom.
After this make the text so it is not solid and group it together.
Math the text up to the pumpkin and stretch it out so it goes midway into the pumpkin.
Create smaller cylinders and remove the floating objects from the text.
Step 3: Creating Corner Shaper
Create a square and place it evenly on 4 tiles.
Then create a hollow cylinder and place it in the bottom left corner of the squares tile.
Group the shapes together and make them not solid.
Step 4: Making the Base Plate
Add the corner shapers evenly to each of the corners
Rotate them so the curve faces the center and group them together.
Step 5: Adding the Bats
Import the bats from here: https://www.tinkercad.com/things/jS8YLQtC2G3-bat
Make them not solid and insert them into the baseplate.
Group all the shapes together.
Step 6: Hollow the Pumpkin
Create a hollow cylinder and place it into the pumpkin slightly raised so there is still a bottom.
Group both parts together.
Step 7: Grouping Base and Pumpkin Together
Select both the base and the pumpkin and align the pumpkin to the center.
Group each part together.
Step 8: Light
Separately print the light source and place it inside the pumpkin. To give it a nice glow.
