Pvc Kids Chair
Intro: Pvc Kids Chair
These chairs are so nice for outside! They fold for easy storage and the covers are washable! I have tested the chairs up to about 45 pounds in weight.
Chair Cover Supplies:
13"x26" fabric for front
13"x26" fabric for back
13"x26" fleece interfacing
Chair Frame Supplies:
About 15' of 1" outer diameter PVC pipe
8- 1" PVC elbows
6- 1" PVC T's
drywall sanding block
STEP 1: Making the Cover
Layer the pieces together, wrong sides facing. Sew around all edges, leaving a space for turning.
STEP 2: Finishing the Cover
Turn right side out. Fold 2 1/2" to the back on each end and pin in place. Sew.
STEP 3: Remove Markings From Pvc
Using the drywall sanding block, sand any marking off the PVC pipe.
STEP 4: Cut the Pvc
Using a miter saw, cut the pipe into the following pieces:
4- 3 3/4", 6- 6 3/4", 4- 12", 3-14"
STEP 5: Bottom Frame
Start by making the bottom frame.Take 1-12" piece and attach elbows to both ends. Attach a 3 3/4" piece to one elbow and a 6 3/4" to the other elbow. Attach a T to both pieces you just placed with the "stem" of the T facing inward. Repeat with another 12". Now join the two frame pieces together using a 14" inserted into the "stem" of the T.
STEP 6: Back Frame
To make the back frame: Insert a 6 3/4" piece into the T on each side and top each piece with another T with the "stem" facing towards you. Insert a 6 3/4 piece on the top part of the T on both sides. Top each piece with an elbow. Join the back frame with a 14" piece.
STEP 7: Completing Chair Frame
Insert a 3 3/4" piece into the T on the front of the chair and top with an elbow. Repeat for other side. Insert a 12" from the elbow to the T on the back. Repeat for other side. Insert your last 14" piece to complete the chair frame.
STEP 8: Double Check
Make sure all of the joints have been pushed together really well.
STEP 9: Finish Chair
Attach fabric cover
6 Comments
debvh51 7 years ago
How does the chair fold up?
jordynstetter 9 years ago
jordynstetter 10 years ago
jjournell 9 years ago
I agree with the lady below, and will add some more to it. Your measurement for the length of the fabric for the piece that runs from top, to bottom, is WAY WAY off, and needs to be near 39 inches to reach/work. I spent $50 on materials for this project, to make 2 of these for a 4H project, to find out all wasted. I have a nice $50 pile of junk thanks to your measurement.
vtbeachldy 10 years ago
