Pyro-Carpenter Bookmarks
Intro: Pyro-Carpenter Bookmarks
Book marks come in various shapes sizes colors and materials. Me I always like a wood grain look to anything and decided, why not try and make a wooden bookmark that one can design themselves. (if they have the tools needed) I use many different woods(cedar,oak,poplar,pine,etc.) some in the picture are made from 200+ year old barn wood.
These bookmarks are not hard to make I recommend though just using a table saw to mill the bookmark instead of planing a board and cutting many from it that is a waste. I will list all materials and tools but some are optional.
Not only am I a carpenter I also damper in wood-burning as a pyrograpist. Wood Burners come in various shapes and sizes some that are smaller some that are bigger. I started off using a soldering iron with modified tips i made for it.(do not recommend) I then moved to what is called a "versa tool" Tool- witch doubled as a soldering iron and a wood-burning tool with a selection of tips. Now as it became more of a hobby and I wanted to become more detailed, I purchases a Nibsburner "Blue Ribbon" model, with detail master styluses. (http://www.nibsburner.com/) With these you have to get used to certain tips such as shading,drawing,curved,feather,scale,shading,writing, and etc. You can either purchase these tips or make your own but have to purchase a special nickle plated wire that is adaptable to your certain burner. There are many tutorials and books on pyrography, but i was self taught. Me myself recommend any Nibsburner wood-burners but be advised you will have to purchase different styluses.(Nibsburner's styluses are made out of a cheap plastic and melt under the heat)
Recommended Brands: Nibsburner, Detail-Master, Burn master, Raxor-Tip, Versa Tool (Hobby burner not expensive)
Materials and tools:
Wood(any choice of wood you would like)
Pencil/pen/marker
Ruler/tape measure
Planer/thickness planer(optional)
Table saw drill drill bits(preferred size)
Twine/string/rope
Sander(electric or by hand)
Wood burner(optional)
Wood stain/polyurethane(optional) "If you want to give it a finished look"
STEP 1: Selecting
Find and locate the type of wood you wish to use. (I tend to go out to our pile of firewood and spit it into a board and throw it through the planer.
STEP 2: Sizing
From this piece of wood cut out a block but that is not too thin. ( I used a poplar wood plank which I split. I made it a 2”x6” rectangle block of wood which was ¾” thick)
STEP 3: Thickness of Bookmark
Take the straight edge on your saw and move it close to the blade of the saw. (for my bookmark I moved the straight edge less than ¼” of an inch roughly .125” away from blade.)
STEP 4: Cutting the Block
Rest the wooden block flush with the straight edge and begin to cut. (Watch your fingers)
STEP 5: Sanding
Take this new cut piece of wood and sand it down.
STEP 6: Drilling
Drill hole in the top to allow twine(or string of choice) to go through and tie a knot
(You can choose to stop here and just have a blank bookmark or continue and add a picture or design to your bookmark)
STEP 7: Design You Wish to Burn
you can do one of three things.
1)Draw the pattern you wish to burn on the bookmark
2)Print out a stencil and trace
3)Print a image then use carbon paper to transfer the image for burning
(the image above shows a carbon paper trace of an image I found)
STEP 8: Heat
Heat the burner up(depending on price and model it may take longer)
STEP 9: Trace
Trace the outline of the design or scene. (with the wood burner using a drawing/writing tip)
STEP 10: Shading and Adding Texture
Shade in the out image you just outlined and adjust your heating to get darker and lighter shades. (use a shading tip)
STEP 11: (optional Do Not Recommend)
Add a coat of polyurethane to give it a different finished look(I found this effects the art and often darkens it too much)
8 Comments
foglemam 8 years ago
Thin strips need to be cut on the open side of the table saw blade unless you have a pushblock made for thin strips. Asking for a kickback when the thin strip gets trapped against the fence. This is an easy one to make:
http://www.woodworkingtips.com/etips/2009/06/18/sn...
LarkinB 8 years ago
Excellent job, Brandon! Especially your art work.
Faissal 8 years ago
really nice...
DaMidas 8 years ago
Where did you get the spider design?
Brandon Boyd 8 years ago
It is a free handed tribal design I drew.
It is just a tribal design I free handed but i'm sure there are many like it you can find online.
Ryhorn12 8 years ago
DIY Hacks and How Tos 8 years ago
Awesome bookmarks
