Introduction: QUICK RELEASE STEERING WHEEL ADAPTERS
This is a quick connector to connect your wheel to a Racing Simulation device.
I designed my DIY wheel with a shaft that is 12mm and the wheel is Momo brand.
If your devices are not the same you can contact me by email at phanphamvietlong@gmail.com or my Facebook is Jensen Phan so I can customize it for your devices, and as if you don't like the name on the part, I will remove it for it.
EVERYTHING is FREE...
P/s: because of the Covid, my job is not stable if you are happy with this you can sponsor for me via Paypal: paypal.me/jensen01
- Steel ball 8mm: 8Pcs - Your can order: Amazon.com : stell ball 8mm
- Spring steel: 4Pcs ( I took them from 4 ballpoint pens).
Step 1: Download File for 3D Printer
We will download the file and unrar to slider G-code of 3 file(Slider, Base, and Shaft)
You can DOWNLOAD HERE: Quick connect Racing Simulation Wheel by long9a - Thingiverse
Step 2: Print 3D File With Config Like Bellow
Print Settings
Printer:Anycubic Zero
Supports: No
Resolution: 0.2
Infill: 20%
Filament Brand: Noname
Filament color: depend on you
Filament material: depend on you - I used PLA
Notes:
Wall: 1.6mm for enough the torsion force when wheel working.
Step 3: Insert the Steel Balls and Springs
Put 8 balls and 4 springs like the picture, and put the Slider part to the Base part.
Step 4: Lubricant for Moving Part
I use cosmetic vaseline. Usually, it is white to transparent and odorless. It's cheap and available in all drugstores and cosmetics stores.
