Quick Reverse Tie-Dye
Intro: Quick Reverse Tie-Dye
I found these navy and black tees on sale and I loved the fit, but I thought that they were a little plain. I wanted to jazz them up a little, but in a subtle way, so that I could still wear them under a jacket or with jewelry.
Typically if you want to tie-dye something, you have to let the dye set for 6-8 hours. With this method, you can be done in less than ten minutes.
Using bleach in a spray bottle, I was able to control how much of the shirt was altered and how much color was removed.
STEP 1: Supplies and Stuff
- a clean dark tee shirt - the darker the better
- a spray bottle
- some rubber bands
- bleach
- a bleach-proof space
Arrange your tee in your bleach-proof space. I have a plastic mannequin set up on my work table. But you can just lay it flat on some plastic bags.
These two instructables may give you some ideas for layouts:
1) Transforming a boring old black t-shirt using bleach!
2) Bleach Spritz Clothing
STEP 2: Don't You Hate Delayed Gratification?
Gently mist your tee shirt. Like magic, every where that a drop of bleach touches, color is removed. Black turns brown and navy turns pink.
How does this happen? According to http://www.howstuffworks.com/question189.htm,
"When you buy a gallon of bleach at the grocery store, what you are buying is the chemical sodium hypochlorite mixed with water in a 5.25-percent solution. You're buying salt water that has been changed slightly by electricity.
"Natural stains (as well as dyes) produced by everything from mildew to grass come from chemical compounds called chromophores. Chromophores can absorb light at specific wavelengths and therefore cause colors. When chlorine reacts with water, it produces hydrochloric acid and atomic oxygen. The oxygen reacts easily with the chromophores to eliminate the portion of its structure that causes the color."
Anyway, the more bleach you use and the longer you leave on, the more color is removed. So, for subtle effects, mist lightly and go to the next step quickly.
On the example photos, I misted the black tee lightly and in an irregular pattern. For the navy blue tee, I went for a more dramatic tie-dye effect by tying rosettes into the fabric, using rubber bands. I also sprayed more heavily.
STEP 3: And... You're Done!
I just dumped mine in the kitchen sink with a little dish soap.
Its ready to wear when dry.
28 Comments
FamilyA1 8 years ago
If I get a purple shirt what color would the bleach make it? Or, what color tee-shirt, when bleach is applied turns it purple?
Thanks!
RemarkableJane 12 years ago
omicronomicron 12 years ago
take care when mixing bleach with detergent or soap, like you said in your last step... this can be dangerous as toxic fumes can be released. I once did this by mistake (in larger quantities) and my dog ran to the front door and stuck his nose through the letter-box! I had to dash out too and it wasn't safe for a few hours. Bleach and soap don't mix.
Bitsi 12 years ago
You might be thinking of mixing bleach with ammonia. See http://chemistry.about.com/b/2010/08/20/why-you-shouldnt-mix-bleach-and-ammonia-bleach-and-ammonia-chemical-reactions.htm
jonpersonals 12 years ago
Bitsi 12 years ago
maybe the detergent I was using had amonia in it, and your doesn't? Glad you replied as it alerted me to exactly what to avoid! Thanks for that...sorry for any confusion...
it's a great Ible anyway... now I feel a bit more reasured! So I will try it,, taking care what NOT to mix.
Not quite accurate. See my comment below... Cheap crap Discount Detergent mite do this,(react with bleach). not Tide or Cheer.
Did it 50 times.
w0x0f 12 years ago
curious youth 12 years ago
westlifelover92 12 years ago
nchae 12 years ago
ewallace2 12 years ago
Bitsi 12 years ago
Post pictures!
MomLovesElectro 12 years ago
I might try this with a few old shirts of mine!
Bitsi 12 years ago
Seezor 12 years ago
https://www.facebook.com/#!/photo.php?fbid=73711558946&set=a.73711133946.76668.589313946&type=1&theater
Bitsi 12 years ago
CrystalDyes 12 years ago
In Discharge Dyeing classes, the bleach is never used full strength. The strongest we use is 50-50 with water. Many instructors go with a 30% bleach solution to 70% water.
