Quick Simple Individual Pizzas
Intro: Quick Simple Individual Pizzas
Here is a recipe for Quick Simple Individual Pizza.
What you will need:
1. Oven
2. Aluminum Foil
3. Spray Oil
4. Pizza Cutter
Ingredients:
1. Flour Tortilla
2. Jar, Can or your very own home made Pizza Sauce
3. Toppings for Pizza (Your choice)
4. Spices, or you can just use tomato sauce like I do
5. Cheese. You can use store bought Cheese, or if you made your own Mozzarella from my recipe you can use that also. The recipe is at:
https://www.instructables.com/id/Great-Mozzarella-Cheese/
What you will need:
1. Oven
2. Aluminum Foil
3. Spray Oil
4. Pizza Cutter
Ingredients:
1. Flour Tortilla
STEP 1: Preheat the Oven
Preheat your oven to 425 degrees so it will be hot when your ready to put the Pizza in.
STEP 2: Starting the Pizza
Tear off a piece of Aluminum Foil and place it on the counter Spray a little Oil on the Foil so the Pizza won't stick. Place your flour Tortilla on the Aluminum Foil.
STEP 3: Adding Sauce
Spoon on whatever type of sauce you like. I use plain old Tomato Sauce and then spice it up the way I like it.
STEP 4: Adding Cheese and Toppings
Add your Cheese and toppings. Whatever you decide to use, chop it up small so it gets a chance to cook. If you use meat you might want to pre cook it a little bit and drain the excess fat off. You can put the toppings either under or on top of the cheese. (Although I guess if you put them under the cheese they probably wouldn't be called toppings. What would they be called???)
STEP 5: Baking Your Pizza
Place your Pizza in the Pre heated oven. You can either place the Pizza and Aluminum Foil on a rack in your oven or just put the Pizza on a Pizza Pan or Pizza Stone. I use the foil so I can just throw it out when finished. The Pizza should bake in about 10 to 15 minutes depending on how brown you like your cheese.
STEP 6: Cut and Enjoy
Cut the Pizza up and put it on a plate. Enjoy!!! You can make up a bunch of these at one time and freeze them to bake later. These are also great for parties where everyone can put on their own toppings and everyone gets involved.
I hope you enjoyed this Instructable.
Please VOTE for me in the Pizza Contest!
Mike
Mike
