Quick and Dirty Electric Tripwire -The Home Guard Mix.
Intro: Quick and Dirty Electric Tripwire -The Home Guard Mix.
Basically just a tripwire based switch made from stuff lying around the house. Can also be used as a remote switch for things you don't want to be next to when you turn them on.
STEP 1: Tools and Stuff, You Will Need...
Clothes Peg
Thin copper plate
Thin card/ plastic
String/ invisible thread
Crocodile clips
Wire
Superglue
Battery
Device you want power
Pen knife or some other kind of cutting implement.
Thin copper plate
Thin card/ plastic
Crocodile clips
Wire
Superglue
Battery
STEP 2: Constructing the Switch.
Cut the copper plate to size. You need two pieces, roughly the same size, big enough to stick to the inner jaws of the peg and have some hanging out the side to attach the crocodile pegs to. It's best to have some stick out of one side on the top and the other side from the bottom.
STEP 3: The Trip Gizmo.
Get your piece of card/ plastic and cut to a decent size. Big enough to seperate the jaws of the peg without the copper pads touching each other.
Poke a hole through one end and tie the tripwire through it.
STEP 4: Finally There.
Insert the card/ plastic break into the peg jaws. Attach the crocodile clips to the pads. The other end of the clipped wires, it is up to you. Light or sound devices will work with this.
You can either wedge it under something , but I put a string through the center of the spring to anchor it to something solid.
Simply put, the card acts as an insulator an gets pulled out when the tripwire is.. well, tripped.
The copper makes contact and the whole thing acts as a switch. Done.
Works well with my Quick and Dirty Squib instructable (but only when used with caution). Check it out, NOW.
24 Comments
flashlight_nut3777 13 years ago
ThinkBeforeYouSpeak 16 years ago
James (pseudo-geek) 16 years ago
PKTraceur 15 years ago
Predictor 14 years ago
boogiemanspud 15 years ago
turner22 15 years ago
turner22 16 years ago
seanilicious 16 years ago
Bartboy 16 years ago
Giller12 16 years ago
Yasuragi 16 years ago
TheInventor 16 years ago
themasterpyro 16 years ago
Alex Palfreman-Brown 16 years ago
nsaltz94 16 years ago
