Introduction: Quick and Easy Textured Crochet Washcloth
About: Hello all!!!! A warm Welcome and It's a pleasure to have you here. Art and Craft is my passion .I love experimenting new and creative ideas.
Crochet Washcloth or Dishcloth patterns are awesomely easy and quick to make projects Hence they are a favorite among many Crocheters. Crocheted Washcloth patterns are great for using up your scrap yarn
Today am sharing the pattern for Quick and Easy Textured Crochet Washcloth. Often Simple stitches combined with each other makes amazing crochet patterns. This washcloth pattern is made with Double Crochet Cluster Stitch combined with Single Crochets.
These two stitches combined together gives the washcloth a rich texture and bulk. Its a One Row Repeat pattern which makes it even more effortless to whip up. With the festive season going on , you can change the yarn color to suit any festive occasion ,be it Christmas or Thanksgiving. They are great for making last minute gifts for your loved ones.
Visit https://rajiscrafthobby.blogspot.com/2025/11/quick-and-easy-textured-crochet.html
10 Ply Bulky Cotton Yarn
6 mm Crochet Hook
Step 1:
Here is the Video Tutorial:-
You can follow along with this tutorial video. Please be sure to subscribe too!
Step 2:
Round 1:-
Start with a Slip Knot.
Chain 21.
You can adjust the size by altering these stitches according to your requirement.
Start with any multiple of 3.
Step 3:
Round 2:-
1 Single Crochet in the 2nd Chain from the hook.
1 Single Crochet each in the remaining stitches.
Once you reach end, Chain 2 and use the Straight Edge Turning Chain to make the turning chain.
Straight Edge Turning Chain:-
Usually you would Chain 2, turn and start working the next round. Here is a quick tip to have a nice straight edge
  1. Insert the hook into the 1st chain from the bottom.
  2. Yarn over and pull up a loop. You should have 2 loops on the hook.
  3. Turn your project and insert the hook into the first stitch.
  4. Yarn over and pull up a loop. You will have 3 loops on the hook.
  5. Again, yarn over and pull through 2 loops. You will have 2 loops on the hook.
  6. Lastly, yarn over and pull through 2 loops.
  7. This will make one Double Crochet.
Step 4:
Round 3:-
1 Double Crochet is already made while making the turning chain.
Skip 1 Stitch.
In the next stitch make - (1 Double Crochet Cluster Stitch, Chain 2, 1 Single Crochet)
Skip 2 stitch.
Repeat(1DC Cluster, Ch2,1SC,Sk2).
At the end you will have 2 stitches left.
Skip 1 Stitch.
1 Double Crochet in the last stitch.
Once you reach the end ,Chain 2 and use the Straight Edge Turning chain mentioned in the previous round to make the turning chain.
How to Make a Double Crochet Cluster Stitch.... ???:-
  1. Yarn over, insert the hook into the stitch, yarn over and pull through 2 loops on the hook.(This is same as doing a Double Crochet Stitch. It is just that , you don't finish the Double Crochet Stitch and continue doing the first part of the Double Crochet Stitch again and again).You should have 2 loops on the hook.
  2. Yarn over, insert the hook in the same stitch, yarn over and pull through 2 loops. You should have 3 loops on the hook.
  3. Continue with the first part of Double Crochet stitch untill you have 4 loops on the hook.
  4. Yarn over and draw the yarn through all 4 loops on the hook.
  5. This makes 1 Double Crochet Cluster Stitch.
Step 5:
Round 4:-
**This Round Onwards We Will Be Working Only into the Chain 2 Spaces.
In the next Chain 2 space make -(1 Double Crochet Cluster Stitch, Chain 2, 1 Single Crochet)
Repeat(1DC Cluster, Ch2,1SC) into each of the Ch2 space.
Once you reach the end ,Chain 2 and use the Straight Edge Turning chain to make the turning chain.
Step 6:
Keep repeating Round 4 untill its Square in shape.
Chain 1 and turn your work.
Step 7:
1 Single Crochet in each stitch and Weave off.
