Quick and Simple Wall Mounting
Intro: Quick and Simple Wall Mounting
A way to make mounting things on the wall/drilling holes much easier.
Items Needed
Option A
Photocopier
Option B
Printer
Scanner
This is all you need, minus the tools for mounting eg stud detector nails etc. Or if you're just working straight into the gib board pins or tacks will work.
STEP 1: Scanning and Printing
Scan and print to 100% scale with a scanner and printer or a photocopier. The option to print to 100% scale should be under your printing/page options.
STEP 2: Mounting
Put the pins/nails/tacks whatever you may in to where they should be mounted while holding the to size printed paper on the wall. After that mount your object and you're done :). Fairly simple, and I didn't come up with this idea myself but I thought I would share a neat little way to mount things while keeping them accurate.
4 Comments
willysnax 7 years ago
I know this Instructable is a couple of years old but if someone happens to come across it like I did, I thought I'd add an idea in case you are in more of a hurry and still need accurate holes for wall mounting.
Put masking tape over the holes on the phone (or whatever) and poke threw or mark them on the tape, then use the tape as your template for the wall. Easy, fast, and accurate every time. Just another option. :)
Jords001 7 years ago
That's pretty clever :D, thanks for the comment!
wilgubeast 9 years ago
Clever. I use the same technique to figure out precise laser cutting sizes for small items. Take a scan, pop it into Illustrator or Corel, then keep the canvas size consistent.
bfarm 9 years ago
So simple - awesome.
