Quick 'n Easy Nitro Engine Starter
Intro: Quick 'n Easy Nitro Engine Starter
A simple homemade rc airplane engine starter from household items.
STEP 1: Purpose
The purpose for me making this instructable is the obvious (well maybe i'm just too oblivious) lack of information helping other new "rc_ers" create a cheap starter. Yup that pretty much sums it up.
STEP 2: Gathering the Parts
This design is so simple and you must be able to find all these parts laying around the house screaming " give me a new life" or so on. Parts:
-quarter inch bolt
-quick disconnect garden hose male plug
-two garden hose rubber washers
-one clear plastic thingy from under the lid of any pop bottle
-quarter inch bolt
STEP 3: Assembly
This design is so brilliant thats it`s even intuitive with the set up. (trying not to gloat)
Step1: get a box
Step2: cut a hole in that box
Step3: put your junk...
oops thinking of something else.
REALLY:
insert the bolt through the hole in the quick attatch with the bolt head on the inside and making sure that it is flush or lower in the hole. Add the clear plastic thingy to protect the nose cone from accidentaly rubbing against anything ugly. Then add the two rubber washers et voila, ta piece de resistance et fini.
Step1: get a box
REALLY:
STEP 4: Test Baby! (and Final Thoughts)
Now go and take it for a spin (no pun intended). This worked out pretty well for just parts laying around the house. a few things to note however: if I were you I would first test fit it against your nose cone since this is NOT an one size fits all. You may find with the larger (.45 and up, maybe even some .40) engines that this adapter will like to just slip and make some nice rubber powder for you to brush off after, and you may wish to experiment with different types of rubber-ish based material, such as silicon sealent, gasket maker, etc etc. And make sure that what ever you do, you DON`T get yourself, or even somehow myself in trouble for whatever should happen, as I will not be held liable for any foreseen or unforeseen accidents. Good Luck and fun Flying or airboating or whatever.
8 Comments
davidneth 14 years ago
Thanks,
D
dealydoo 15 years ago
Matt D655 15 years ago
mehmikekylee 15 years ago
Syko Pyro 15 years ago
GorillazMiko 16 years ago
