R2D2 Beer Cooler / Ice Box
Intro: R2D2 Beer Cooler / Ice Box
PLAN - Make an R2D2 model that was functional
RESULT - BEER FRIDGE/ICE CHEST R2D2 made from 44 gallon drum
Materials:
- 44 Gallon drum (drain/burn off contents)
- BBQ lid to fit on top (57cm lid works great)
- Timber for legs
- Primer
- White paint
- Silver and Blue spray paint
- Spray on rust proof sealant (stops spray pain running and makes it more stain resistant)
- Transparencies for stencils
- Cutting blade
- Drill, circular saw, jis saw, angle grinder, hand saw, orbital sander, lathe, jackhammer
- Irrigation fittings
- Old sunglasses lens
- LEDs and wiring/resistors
- Gap filler
- Polystyrene
- Plastic plant pot
- Large plastic bin
STEP 1: Prepare the Drum
With a hammer drill chisel, cut the top off
Drain contents and if toxic (oil, petrol) collect it and dump it at the nearest mechanic (they have a collection system there that recycles it)
Wash out or burn off the remaining residue
Even out the inside cut with the angle grinder to remove sharp edges
STEP 2: Make the Legs
I made the legs so that the drum would actually sit on TOP of the base of the leg, holding up all the weight.
This meant less stress on the side bolts going into the barrell
Steps:
- Cut a piece to length
- draw, cut out and sand the shape of the foot
- Measure and cut out the raised outer section of the legs
- Glue and drill from behind the raised section
- Lathe the joins smooth and sand back
- ensure clean edges at this stage for a nice finish
STEP 3: Make the Feet
To make the feet, I cut out some lengths at an angle with the circular saw (be careful here)
The inner piece of each foot had a larger "shelf" on top that is where the drum sits on
The outer pieces are thinner at the top
Glue and screw these side pieces in (counter drill to hide screws)
Then cut and fit the smaller triangles that fill the gaps. Watch there you put the screws to not hit the ones already in there
Lathe and sand back the joins to smooth
Fill all the holes with gap filler, dry and sand back
Measure and drill the holes that will go into the drum
Now you are ready to prime and paint the legs and barrel
STEP 4: The Lid
Find some irrigation fittings and SCREW and GLUE them into the lid (glue only = likely to fall off)
Seal holes made
Apply primer evenly and then spray the lid silver
For the raised up square I actually found an old whisky bottle box lid that inside was scare and blue
I then cut out a round section from an sunglasses lens and glued that into the whisky lid (see later images)
STEP 5: Prepare Drum
Prime EVERTHING with white primer first
Then paint the drum white, but leaving a silver strip at the top using masking tape and silver spray paint
Paint the legs white as well
The easiest way I found to make the inside insulated and waterproof was to:
- find the right plastic bin to fit inside drum
- Main issue was the height, so I used an upside down plastic plant pot to sit the bin on and bring it to the right height
- Drill flower pot into the base for stability
- Fill cavity with broken bits of polystrene
- At the top fill the top edge with gap filler, let it cure and then cut off excess, leaving smooth edge
STEP 6: Paint Job
Cut out stencils from transparency paper (durable and flexible)
Spray stencils as desired (time consuming...)
Glue and drill blue box onto lid (last photo)
Go over the stencil edges withe black thin marker to smooth them out
Seal everything with spray on rust protection sealant
STEP 7: LEDs
Get a large Red and smaller yellow or white LED
Drill holes where you want them, feel them through and glue them in place
Solder/heatshrink the conections to resistors and battery pack (see separate posts for instructions)
Secure to inside of lid
STEP 8: ENJOY YOUR WORK
Overall, I am very happy with the final result !
The only things I would do differently are:
- Apply primer evenly. Because i did not paint over the primer on the lid with "real" wet paint, but spray paint instead, the finish remained irregular and you can see the brush strokes
The drum and legs were fine because I painted them with the white paint
I got most of these ideas from this site, you tube, google etc so look around and make a plan!
Enjoy guys and girls!
3 Comments
ClenseYourPallet 7 years ago
Alex in NZ 7 years ago
That is so cool. Awesome!
DIY Hacks and How Tos 7 years ago
Cool idea.
