R2D2M2 -- ISS Antenna Tracker
Intro: R2D2M2 -- ISS Antenna Tracker
Connecting to the International Space Station (ISS) requires tracking a moving object traveling at 17,000 MPH orbiting 250 miles above the Earth. This is actually moving a little slower than the second hand on your watch. However, this is moving faster than you may realize.
You could purchase a commercial Az/El rotor system for $1,350 from Yaesu or you can build your own.
Let's get started!
This project does not cover the assembly of Arduino micro controllers. This may be a future topic covered separately.
Useful tools: 7/64" hex key, 3/32" hex key and a #1 Phillips Screwdriver
Actobotics Servo Controller
https://www.servocity.com/actoboticsr-servo-contro...
Yaesu Az/El Rotor (for functional comparison this project)
https://www.yaesu.com/indexVS.cfm?cmd=DisplayProdu...
Ham Radio Outlet
https://www.hamradio.com/detail.cfm?pid=H0-002765
STEP 1: Assembling the Base to Support the X-axis
Gear Drive Pan Kit Description: N/A
Part Description: 12.00” Aluminum Channel
https://www.servocity.com/12-0-channel
$9.99
Part: 585454
Step 1: Quantity: 1
Gear Drive Pan Kit Description: 1” OD x 2.25” L Aluminum Tube with Flange
Part Description: 1" Flanged Aluminum Tubing
https://www.servocity.com/1-00-flanged-aluminum-tu...
$3.49
Part: 635166
Step 1: Quantity: 1
Gear Drive Pan Kit Description: 1” Shafting and Tubing Spacer
Part Description: Shafting and Tubing Spacers (12 pack)
https://www.servocity.com/shafting-and-tubing-spac...
$1.69 (12 pack)
Part: 633116
Step 1: Quantity: 1 of 12 pack
Gear Drive Pan Kit Description: 6-32 x 0.3125” Socket Head Cap Screws
Part Description: 6-32 Flat Head Phillips Machine Screws
Notes: 6mm, 32tpi, 5/16” length
https://www.servocity.com/6-32-zinc-plated-socket-...
$1.79 (25 pack) * 2
Part: 632108
Step 1: Quantity: 8 + 2 = 10
Gear Drive Pan Kit Description: 6-32 x 0.500” Socket Head Cap Screws
Notes: 6mm, 32tpi, 1/2” length
$2.19 (25 pack) * 1
Part: 632114
Step 1: Quantity: 4
Gear Drive Pan Kit Description: 1” Bore Clamping Hub A
Part Description: 1" Bore, Face Tapped Clamping Hub, 1.50" Pattern
Notes: Tapped
URL: https://www.servocity.com/1-bore-clamping-hub-a
$5.99
Part: 545352
Step 1: Quantity: 1
Gear Drive Pan Kit Description: 84T, 32 Pitch, 1” Bore Aluminum Hub Gear
Part Description: 1.00" Bore 32 Pitch Aluminum Hub Gears
URL: https://www.servocity.com/32p-1-00-bore-aluminum-...
$12.99
Part: 615226
Step 1: Quantity: 1
Gear Drive Pan Kit Description: Hub Adaptor C
Part Description: 1.50" - 1.50" Pattern Adapter
URL: https://www.servocity.com/hub-adaptor-c
$3.99
Part: 545500
Step 1: Quantity: 1
Gear Drive Pan Kit Description: Aluminum Clamping Motor Mount
Part Description: 37mm Bore Bottom Tapped Clamping Mount
URL: https://www.servocity.com/37mm-clamping-motor-mou...
$6.99
Part: 555116
Step 1: Quantity: 1
Gear Drive Pan Kit Description: 20T, 32 Pitch, 6mm Bore Pinion Gear
URL: https://www.servocity.com/6mm-bore-32p-shaft-moun...
$7.99
Part: 615262
Step 1: Quantity: 1
Gear Drive Pan Kit Description: 1” Bearing Blocks
Part Description: 1" Bore Side Tapped Pillow Block
URL: https://www.servocity.com/1-000-bore-quad-pillow-...
$9.99
Part: 535178
Step 1: Quantity: 2
STEP 2: [2 of 12] Attach the Camera Screw Socket to the Base
Gear Drive Pan Kit Description: 90 Degree Dual Side Mount D (pair)
Part Description: 90 Degree Dual Side Mount D (2 pack)
https://www.servocity.com/90-dual-side-mount-d
$6.99
Step 2: Quantity: 1 pair, 2 pack
Gear Drive Pan Kit Description: Round Base A
Part Description: 6.00” Aluminum Channel
https://www.servocity.com/round-base-a
$6.99
Part: 585438
Step 2: Quantity: 1
Gear Drive Pan Kit Description: 6-32 x 0.250” Flat Head Stainless Steel Screws
https://www.servocity.com/6-32-flat-head-phillips-...
$0.15
Part: 91771A144
Step 2: Quantity: 8
$1.79 (25 pack) * 2
Part: 632108
Step 2: Quantity: 4
Gear Drive Pan Kit Description: 1/4-20 Round Screw Plate
Part Description: 1/4"-20 Round Screw Plate
URL: https://www.servocity.com/0-250-20-round-screw-pl...
$3.99
Part: 545468
Step 2: Quantity: 1
STEP 3: [3 of 12] Attach the Base to the Camera Tripod
Use any tripod designed to support a 10 pound video camera.
STEP 4: [4 of 12] Assemble the X-axis
https://www.servocity.com/6-0-channel
$5.99
Part: 585446
Step 4: Quantity: 1
$3.49
Part: 635166
Step 4: Quantity: 1
$1.69 (12 pack)
Part: 633116
Step 4: Quantity: 1 of 12 pack
$1.79 (25 pack) * 2
Part: 632108
Step 4: Quantity: 8 + 2 = 10
$2.19 (25 pack) * 1
Part: 632114
Step 4: Quantity: 4
Notes: Tapped
$5.99
Part: 545352
Step 4: Quantity: 1
$12.99
Part: 615226
Step 4: Quantity: 1
$3.99
Part: 545500
Step 4: Quantity: 1
$6.99
Part: 555116
Step 4: Quantity: 1
$7.99
Part: 615262
Step 4: Quantity: 1
$9.99
Part: 535178
Step 4: Quantity: 2
STEP 5: [5 of 12] Mount the X-axis to the Base Channel
https://www.servocity.com/6-32-zinc-plated-socket-head-machine-screws
$1.79 (25 pack)
Part: 632108
Step 5: Quantity: 4 (of 25 pack)
STEP 6: [6 of 12] Assemble the Y-axis Channel
$5.99
Part: 585446
Step 6: Quantity: 1
$3.49
Part: 635166
Step 6: Quantity: 1
$1.69 (12 pack)
Part: 633116
Step 6: Quantity: 1 of 12 pack
$1.79 (25 pack) * 2
Part: 632108
Step 6: Quantity: 8 + 2 = 10
$2.19 (25 pack) * 1
Part: 632114
Step 6: Quantity: 4
Notes: Tapped
$5.99
Part: 545352
Step 6: Quantity: 1
$12.99
Part: 615226
Step 6: Quantity: 1
$3.99
Part: 545500
Step 6: Quantity: 1
$6.99
Part: 555116
Step 6: Quantity: 1
$7.99
Part: 615262
Step 6: Quantity: 1
$9.99
Part: 535178
Step 6: Quantity: 2
STEP 7: [7 of 12] Attach Y-Axis Against X-Axis
$1.79 (25 pack) * 2
Part: 632108
Step 7: Quantity: 4
STEP 8: [8 of 12] Assemble Z-Axis Channel
Gear Drive Pan Kit Description: 3.75” Aluminum Channel
Part Description: 3.75” Aluminum Channel
https://www.servocity.com/3-75-channel
$4.49
Part: 585443
Step 8: Quantity: 1
$1.79 (25 pack)
Part: 632108
Step 8: Quantity: 4
$2.19 (25 pack) * 1
Part: 632114
Step 8: Quantity: 4
Gear Drive Pan Kit Description: N/A “Big L”
Part Description: 90° Pattern Mount
URL: https://www.servocity.com/90-hub-mount-bracket-a
$9.99
Part: 535178
Step 8: Quantity: 1
STEP 9: [9 of 12] Attach Z-Axis Channel
$2.19 (25 pack) * 1
Part: 632114
Step 9: Quantity: 4
STEP 10: [10 of 12] Attach X-Axis Motor
Part Description: 4 RPM Gear Motor
URL: https://www.servocity.com/4-rpm-gear-motor
$24.99
Part: 638162
Step 10: Quantity: 1
$2.19 (25 pack) * 1
Part: 632114
STEP 11: [11 of 12] Attach the Y-Axis Motor
Part Description: 0.5 RPM Gear Motor
URL: https://www.servocity.com/0-5-rpm-gear-motor
$24.99
Part: 638142
Step 11: Quantity: 1
$2.19 (25 pack) * 1
Part: 632114
STEP 12: [12 of 12] Attach Z-Axis Motor
URL: https://www.servocity.com/2-rpm-gear-motor
$24.99
Part: 638154
Step 12: Quantity: 1
$2.19 (25 pack)
Part: 632114
Step 12: Quantity: 1 (of 25 pack)
2 Comments
walkercreations 4 years ago
Swansong 6 years ago
That's really neat! I'd have loved to have access to something like this in science class in school :)
