RC AIRPLANE MODELLING ESSENTIALS
Intro: RC AIRPLANE MODELLING ESSENTIALS
This instructable will guide you through the electronic components, parts, tools and building materials required to start modelling your own foam-based electric RC planes.
STEP 1: BEFORE YOU BEGIN
It is advised to be in possession of these elements prior to engaging in your hobby to ensure good health and peace of mind :
1) A personal space
2) A table and a chair you are comfortable with
3) A good source of lighting
4) A spike buster
It is recommended to work on a 4 Ft X 2 Ft table as most of the models will be built out of a 30" X 20" sheet of laminated foam.
STEP 2: THE ESSENTIAL ONLINE CALCULATORS
We will be using these online calculators very frequently on our journey to design our own models :
STEP 3: THE ELECTRONICS
1) A 2.4 GHz R.F Transmitter, Receiver and power pack for the transmitter
2) A Lithium Polymer battery pack, voltage indicator cum low voltage alarm and a LiPo battery charger
3) XT60, Dean, JST and 3.5mm bullet connectors
4) Assorted PVC wires and heat shrink tubing
5) Electronic Speed Controller, Battery Eliminator Circuit and a servo tester
6) Brushless and Brushed DC motors
7) Servo motors, servo extensions and Y splitters
STEP 4: THE REQUIRED PARTS AND ACCESSORIES
1) Assorted electric propellers, propeller adapters and a propeller balancer
2) BLDC motor mounts
3) Control rods and horns, clevises and linkage stoppers
4) Landing gear wheels and mount
STEP 5: THE SUGGESTED TOOLS
1) A soldering station
2) A hot glue gun
3) A precision screwdriver set and magnetic screw tray
4) A set of Allen keys
5) A precision knife, pair of scissors and nippers
6) A multimeter, digital weighing scale and meter scale
STEP 6: THE BUILDING MATERIALS, FASTENERS AND ADHESIVES
BUILDING MATERIALS :
1) Paper laminated foam board
2) Corrugated plastic
3) Thermocol ( Polystyrene) sheets
4) Balsa wood sheets
5) Carbon fibre strips and rods
6) Bamboo skewers and popsicle sticks
FASTENERS :
1) Nuts, bolts stand offs and washers
2) Zip ties
3) Velcro straps
4) Rubber bands
ADHESIVES :
1) Hot glue sticks
2) General glue
3) Super glue
4) Epoxy resin
5) Packing tape, Electrical tape, Double sided tape and glass fibre tape
STEP 7: RECOMMENED BUY LIST FOR BEGINNERS ( INDIA EXCLUSIVE ) :
1) ELECTRONICS :
Communication system : FlySky CT6B Tx Rx 6 channels
1.5 V AA cells ( 8 pcs ) : Envie AA 1000 4PL Ni-CD Rechargeable
LiPo battery:Orange 3S 1000 mAh 30C/40C
LiPo battery charger : SkyRC E3 2S-3S LiPo
LiPo low voltage alarm cum voltmeter : 1S-8S voltmeter
ESC : SimonK 30A 2S-3S
Servo tester : Multi tester
BLDC motor : A2212 1000KV Out runner
Servo motors ( 2 pcs ) : SG90 Mini 180
Servo extensions ( 2 pcs ) :150 mm extender
Servo Y splitter :150 mm Y splitter
2) PARTS AND ACCESSORIES :
Electric propellers :Orange HD Propellers (8X4.5) Glass Fiber Nylon Gray 1CW+1CCW
Control rods : D1X650mm
Control horns : 16x20mm
Tricycle landing gear : Landing gear
3) TOOLS :
Soldering station : 8 in 1
Precision screwdriver : Jackly 33 in 1
Allen keys : Stanley 69-253 10 pieces
Hot glue gun : Stanley 40 Watts
Multimeter : Digital Multimeter Small Yellow Color LCD AC DC Measuring Voltage Current
Precision knife : Precision knife
Digital weighing scale : Max 5 KG
4) BUILDING MATERIALS, FASTENERS AND ADHESIVES :
Foam sheet : FliteBoard 30" x 20" 5mm 5 sheets
Nuts, bolts and washers: M3 15mm SS Allen bolts
Bamboo skewers : 12 inches
Velcro strap : 30cm strap
Rubber bands : 3mm wide 20 pcs
Glue sticks : Themisto Milky White
STEP 8: RECOMMENED BUY LIST FOR BEGINNERS ( GLOBAL ) :
1) ELECTRONICS :
Communication system : Turnigy T6A-V2 AFHDS Mode 2 2.4GHz 6Ch Transmitter w/Receiver
LiPo battery : Turnigy nano-tech 1000mah 3S 25~50C Lipo Pack
LiPo battery charger : Turnigy Accucel-6 80W 10A 1~6S Balancer/Charger
LiPo low voltage alarm cum voltmeter : HobbyKing™ BX100 1~8S Twin Buzzer LiPo/LiFe/Li-Ion Voltage Checker
ESC : HobbyKing 30A (2~4S) ESC 3A UBEC
Servo tester : HobbyKing™ Servo Tester
BLDC motor : Turnigy L2210C-1200 Brushless Motor (150w)
Servo motors ( 2 pcs ) : HXT900 Micro Servo 1.6kg / 0.12sec / 9g
Servo extensions ( 2 pcs ) : 10cm Servo Lead Extension (JR) 26AWG (10pcs/bag)
Servo Y splitter : 30cm Servo Y Lead (Futaba) (5pcs/bag)
Electric propellers : Gemfan Glass Nylon 1045 2- Bladed Propeller Black (CW/CCW)
Control horns : Horn X-Large w/ Clevis 55x40mm and eyelet (5sets)
Tricycle landing gear : Tail Wheel Assembly and Alloy Landing Gear With 90mm Wheels
3) TOOLS :
Soldering station : RadioShack Soldering Starter Kit with 20W Soldering Iron
Precision screwdriver : RadioShack 6-Piece Precision Electronics Screwdriver Set
Allen keys : TEKTON Hex Key Wrench Set
Hot glue gun : STANLEY Glue Gun
Multimeter : Turnigy 870E Digital Multimeter w/Backlit Display
Precision knife : Hobby Precision No 1 Modelling Knife with No 11 Blade and Safety Cover
Digital weighing scale : Amazon Basics Stainless Steel Digital Kitchen Scale with LCD Display, Batteries Included
Foam sheet : Flite Test Water-Resistant Foam Board By Adams (25 Pack)
Velcro strap : Optipower Hook & Loop Battery Strap (Medium) (20x225mm)
Glue sticks : Flite Test 10" Hot Glue Sticks (10)
STEP 9: MISCELLANEOUS
If you are interested in documenting and publishing your work then these will be a good addition to your arsenal :
1) A digital camera and/or videocam and accessories
2) Camera flashes and accessories
3) A microphone to plug into your camera
4) A decent full sized tripod
5) Digital storage devices and accessories
6) A Personal Computer
7) A scientific calculator
STEP 10: FLY HIGH!
Ensure to check the guidelines put forth by your state before your maiden flight.
Make sure to bring all the necessary repair tools and parts with you to the flight club.
Don't fly in crowded zones and avoid flying with the wind.
Click here for more information regarding the legality of flying your RC models. ( INDIA EXCLUSIVE )
Consider following me on my Instagram page :
