Introduction: RC Car Chassis for 1/43 Scale Bodies
This is a chassis for 1/43 scale bodies like Carrera Go, SCX Compact or other bodies.
With this chassis you can convert almost every 1/43 scale car to a RC car.
Find all parts on printables.com as well
https://www.printables.com/model/364941-rc-car-chassis-for-143-scale-body
Follow me on Instagram for latest news
Step 1: Parts to Print
All parts are printed in PLA.
1x chassis (select the correct width and with front mount or just side mount)
2x front rim (select right size)
2x rear rim (select right size)
2x front tire
2x rear tire
1x motor pod
1x t-plate
1x front bracket
1x push rod
1x rear standoff
1x front standoff
1x top plate
1x steering hub left
1x steering hub right
2x side mount (if you have the chassis with just side mount, you'll need 4)
1x front mount part 1
1x front mount part 2
Chassis side 39.stl
Chassis front 39.stl
Chassis side 38.stl
Chassis front 38.stl
Chassis side 37.stl
Chassis front 37.stl
Chassis side 36.stl
Chassis front 36.stl
Rear rim 11x7.stl
Front rim 11x4.5.stl
Front tire 12.5x4.5.stl
Rear tire 12.5x7.stl
Rear rim 12.5x7.stl
Front rim 12.5x4.5.stl
Rear tire 11x7.stl
Front tire 11x4.5.stl
Rear tire 12x7.stl
Front tire 12x4.5.stl
Rear rim 12x7.stl
Front rim 12x4.5.stl
Front mount part 2.stl
Front mount part 1.stl
Steering hub right.stl
Steering hub left.stl
Front bracket.stl
Push rod.stl
Front stand off.stl
Rear standoff.stl
Top plate.stl
Side mount.stl
Motor pod.stl
T-Plate.stl
Step 2: Parts You Need (BOM)
1x MG90 Servo (Use these or search for "MiToot" as you have to drill one gear with a 2mm drill. Others might break)
2x M2 lock nuts
5x M2 washer
1x 1s Battery and charger (take care of the dimension of your chassis and order the correct battery)
1x Spring Steel 0.7mm or 0.8mm
1x Transmitter (if you don't already have one)
1x Micro Receiver (if you don't already have one)
1x AIO FPV camera (optional)
2x Resistors (2.7K should work an all Servo)
Drill bits with 1.7mm, 1.8mm, 1.9mm, 2.0mm
Step 3: Assemble Main Plate
Assembling the main plate is straight forward. You just need the parts and six M2 x 6mm screws.
Step 4: Steering Servo
Attach the steering servo to the front bracket. Attach the smallest servo horn to the servo.
Use a 0.7mm or 0.8mm push rod for steering.
Step 5: Prepare Servo As Motor
This chassis is driven by a MG90 servo. I've found out, that there are a lot of different MG90 servos. Try to buy the one from the BOM, as the different servos have different gears.
From the servo we need the motor, control board, the gear directly next to the motor, the pin from this gear and the gear on the bottom right.
Drill the hole from the bottom right gear CAREFULLY to 1.9mm. If the gear is not made from aluminum/brass, it might be difficult to drill the hole to 1.9mm.
Use the controller board from the servo as ESC. As the servo isn't meant to function as a standard motor, we have to prepare the controller board for this.
Therefore you have to unsolder the potentiometer from the board and solder two resistors between the pins. (Yes, you can leave the potentiometer there and glue it to secure the position. But this takes a lot of space.)
Here you can find another guide how to convert the servo (https://www.circuitbread.com/tutorials/how-to-make-a-360-degree-continuous-rotation-servo-motor)
Step 6: Motor Pod
Add two bearings (left and right) to the Motor Pod. Add the gear from the servo which was next to the motor to the Motor Pod and secure it with the pin.
Cut a M2 rod to the correct length and attach it with the other gear to the motor pod. Don't forget to add a spacer, so that the gear with the rod will stay in place. Secure the gear with some CA-Glue or Loctite to the rod.
Step 7: Front Wheels
Step 8: Mounting Points on Body
Depending on your body, you might have to shorten the front mount.
Step 9: Electronics
There is not much to say about the electronics. I've glued the receiver with some hot glue to the top plate and the "ESC" to the motor pod. Depending on the body you are using, you might have to find another place.
Step 10: Ready to Run
Attach the body to the chassis and that's it. You can also add a small AIO FPV camera to the body :-D
