RGB LED Color Mixing Touch Toy for Kids
Intro: RGB LED Color Mixing Touch Toy for Kids
I want to create an interactive toy for my kids to play with me. We hold hands together then the RGB LED shows different colors. Hold tighter or lighter, or touch different parts of other's body will show different colors. i.e. different brightness of red, green and blue will mix a completely new color. That will be fun.
STEP 1: The Final Product
There are four touch pads: one as common, three others for Red, Green and Blue.
I was planning to touch the common pad by myself, then my kids use one hand to touch red or green or blue, and the other hand to touch me so the RGB LED will show different colors. Soon I found this is a stupid idea. My kids found pressing me harder their controlled color will be brighter so they press me really hard yet sometimes pressing my nose.
So the game changed to: all kids use one hand to touch the common pad and the other hand to touch red or green or blue pad. They alter colors by pressing harder or lighter on the pads. Not on me :)
STEP 2: What You Need and How the Circuit Works
BOM:
- pnp transistors x 3 (I used 8550)
- resistors x 3 (from 100 ohm to 300 ohm depending what you have)
- RGB LED x 1
- some wires and aluminum stickers
- battery (I used 1.2v x 3)
- one breadboard
The circuit is simple. Here is how it works:
- When one uses hands to touch the common pad (ground) and the color pad, the human resistant changes from several hundred k ohm to several m ohm
- The effect is like connecting pins B and C with different resistor allowing current pass through B and C
- The current is amplified by pnp transistor between pin E and C
So pressing the pads harder and lighter, the human resistant will be different that alter the current pass through LED. Different brightness of red, green and blue mix different color in the RGB LED.
- RGB LED x 1
- one breadboard
STEP 3: Assembly and Play
Assemble all parts into the breadboard as attached based on the circuit.
RGB LED is in fact a LED with three LED inside: red, green and blue LED. All LED share same common anode (in my case). Red, green and blue should connect in series with different resistors to get best brightness. But for this case the value of resistor does not matter. As long as the value is big enough to protect the LED, that is fine. i.e. any resistors with value 100 to 300 ohm should work.
Use a sand paper to brush the surface of the LED so you can see color diffusion that makes the color mixing effect matter.
After assembly, plug in power then try
- use one hand to touch the common pad
- use the other hand to touch red wire. You should see LED show red. Press harder then the LED will show red brighter
- touch the other green and blue wires and try the same
- at last try to use different fingers to touch different pads to mix colors. e.g. touch red and green evenly will show yellow. press red harder and green lighter will show orange
Well done. You may now ask your kids control different colors so they mix color together. Turn off your living room light for better effect.
STEP 4: Alternatives If You Don't Have Pnp Transistors
If you don't have pnp but with some npn transistors, you can use the following circuit.
The circuit and effect are similar but the common pad is now connecting to positive power source and pin E is now connected to ground.
Have fun!
Have fun!
6 Comments
Cats Science Club 9 years ago
I think I understand and I am pretty excited to try this. So the lights don't come on unless you touch the common pad with one hand and another color pad? Or are they always on and when one touches the pads they change color?
whalescwh 9 years ago
The circuit will not turn on led unless you press on both common pad and one of the base pad.
However if you want the led on without touch, you can put a high resistance resistor , 500koham or above, between common pad and the base pad. Depending on the resistance, a default color will shown. When press your fingers on the pads, your body resistance will be in parallel with the high resistator, so change the resistance between pads hence the color of the led.
Thank you!
This is great! Ever put in any sound?
djgriff0001 10 years ago
whalescwh 10 years ago
Yes. For kids to play, better solder everything and protect the core well. Toy should not broke in one minute and lose fun :)
I have been planning to make a RGB torch. Different grip and pressure will show different color. Two kids can play generating color matching others.
