Introduction: Radio/wireless Headphones
(Warning to the reader i am trying to sound smart by using technical words that i think fit so please dont yell at me for it because im a beginner)
have you ever been wanting to listen to the radio or casually listening to your music when Shabam!!!
all of a sudden your headphone wires decide to wrap themselves up in knots for know other reason than to irritate you.
well beleive it or not i too had this problem and decided to remedy it
but how will you remove the wires?
not with bluetooth not with wax string or even telecommunication satelites.... no i will use the reliable american backbone that is Radio!
Step 1: Materials
like all other instructables there are some prerequisite items you must use/borrow
1)you will need a pair of head phones that are of the earmuff variety and have large speaker housings
2)you will need any kind of radio(with scan button)that you can most likely buy at the dollar store as long as it is small
3)hot glue or any other suitable adhesive
5)a soldering iron, solder,and basic knowledge on how to use it
6)a screwdriver
7) copper wire
Step 2: Open the El Cheapo Radio
very basic just undo any screws and it should come open unless theres litle catches around the edges. mine only had one screw and no catches so it was pretty easy. after opening remember to find a way to house the battery. i found it was easy to remove the whole set up and use that as a holder.
Step 3: Crack Er' Open
very easy step open your headphones
Step 4: Add the Technical Parts
this is probably the most technical part. you have to solder an on/off switch and a buton(i.e. from some old vhs player or something of the sort) to the circut board.
Step 5: Make Room
your litle buttons need room to reside so why not melt or saw a hole for them
Step 6: Put It All Together
now you want to attach your buttons to those wholes
Step 7: Now Attach the Speaker
now all you have to do is solder the leads of the speaker directly to the radios leads
Step 8: Put It All Together
now just put it back together and walah!! you got yourself a radio headset i actually had a broken set of headphones so i only used one headphone, but i think it still works.
Step 9: Wireless Portion
if you were to add one of those radio transmiters that you plug into your ipod for a car then you would make the wireles portion of this complete
3 Comments
10 years ago on Introduction
walah? like a tea wallah?
11 years ago on Introduction
Is the sound quality still good?
Reply 11 years ago on Introduction
for the radio its only as good as the radio was, but through the headphone jack its still just as good
