Rainbow Loom Butterfly Cha
Intro: Rainbow Loom Butterfly Cha
STEP 1:
Arrange your loom so the arrow points toward you and looks like this.
STEP 2:
Get out about 8 rubber bands
STEP 3:
Put 1 single rubber band on your first peg
STEP 4:
Put 2 rubber bands on the peg below it making sure the end is overlapping the previous bands
STEP 5:
Put on another 2 bands under the previous bands
STEP 6:
This will be your capping band, loop 1 single band around your hook 4 times, you will see 4 loops
STEP 7:
Carefully put the capping band on the need of your butterfly's body.
STEP 8:
For the wings you need 12 rubber bands
STEP 9:
Put 3 rubber bands on the peg 2nd down from the top, to the peg on the top right.
STEP 10:
Continue to lay 3 bands on each of the pegs shown.
STEP 11:
We will now begin looming, it is very simple. :)
STEP 12:
Make sure the arrow on your loom is still pointing towards you. Go under your capping band with your hook and grab the bottom 2 bands. Hold down your capping band and bring the two rubber bands up, and on to the peg above it.
STEP 13:
Continue to go under all the wing rubber bands and grab the 2 bottom with your hook, pulling them both to the peg above it.
STEP 14:
Go through under ALL the bands on the second peg down, get a band, the color you want the antenna of your butterfly to be, and pull it through all the bands. Hold on to the band. There should obviously be 2 ends of the band, grab 1 and pull it through the other end( pull it through itself)
STEP 15:
Your butterfly is almost done, it should look like the image. the last rubber band on the top peg is the charm loop. Take one of the ends and loop it through the other end ( pull it through itself) like the previous step.
STEP 16:
Carefully take your butterfly of your loom. Straighten out your butterfly and get out scissors and 3 more bands, the color of the butterfly's body.
STEP 17:
Using your rubber bands we will make the head and stripes. Twist your first rubber band around your 2 loops on the top of the butterfly until it is very tight, that is the head.
STEP 18:
Take your next rubber band and twist it around the body , in between the top and bottom set of wings and twist it until it is tight.
STEP 19:
Carefully twist your last band on the bottom tip of the butterfly, then go to the top of your butterfly and cut the left loop in half to become your 2 antenna.
STEP 20:
That is your butterfly! :) thanks for viewing!
13 Comments
potanlor000 1 year ago
Ellaboy123 5 years ago
minnie23 9 years ago
you are really good and can you make the smiley face charm your the best
holly the wally 9 years ago
deangera10637 9 years ago
kawaiilover 10 years ago
105415 10 years ago
MadeByLili 10 years ago
Newell_Jalynn 10 years ago
