Introduction: Rainbowloom Bracelet
Rainbow loom is a bracelet that is made out of little rubber bands.
Step 1:
First, take loom out of the box.
Step 2:
Second, start from the side with arrows pointing toward you.
Step 3:
Third, lay the first rubber band.
Step 4:
Fourth, lay the 2nd rubber band.
Step 5:
Fifth, continue laying the rubber bands until you reach the end.
Step 6:
Sixth, turn the loom around so now the arrows are pointing toward you.
Step 7:
Seventh, use the hook to pick up the 2nd rubber band.
Step 8:
Eighth, pull it up so it releases from the pin pull it and hook it on to the forward pin.
Step 9:
Ninth, pull ht third rubber band up so it releases from the pin pull it and hook it on to the forward pin.
Step 10:
Tenth, repeat the steps 7,8 and 9 until you reach the other side if the loom.
Step 11:
Eleventh, loop the last rubber band on to the adjacent pin.
Step 12:
Twelfth, secure the last rubber band with a c clip and remove it from the loom
Step 13:
Thirteenth, Secure the other end with the c clip.
Step 14:
Fourteenth, ENJOY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
