Raised Dog Food Bowls
Intro: Raised Dog Food Bowls
STEP 1: Tools
STEP 2: Materials
Find a bowl that suits the amount of kibble your dog will be fed. Now find a terracotta flower pot that the bowl will fit into. I took the bowl into the hardware store and tried a bunch on for size until I found a good fit. Grab another of the same size and stack them bottom to bottom to see if that height will work. Pick up a large nut and bolt that will fit through the drainage hole and that is long enough to pass though both pots. Pick up two fender washers that are larger than the drainage hole in the pots. (I'm not giving specific sizes because each configuration will depend on the flower pots you select.)
STEP 3: Stack It.
Stack the flower pots bottom to bottom.
STEP 4: Thread It.
Run the bolt through one fender washer and then through the drainage holes.
STEP 5: Cinch It.
Place the other fender washer and the nut on the bolt. Tighten very carefully with the socket wrenches. You just want to snug them up. If you over tighten these, you will break the bottoms of the flower pots.
STEP 6: Drop In.
Drop the bowl in the top pot and you're good to go.
STEP 7: Feed 'em.
I was able to make two of these for about $20. The height on this set was about 11.5" which works out pretty well for these two pups. I think the terracotta looks nice but these could be painted if that look doesn't work for you.
6 Comments
SandraT70 5 years ago
kkoshar 3 years ago
kkoshar 5 years ago
greybunny 7 years ago
I've been having a problem with vermin coming in through my dog door to the garage (then outside). This looks like a great idea but my German Shepherd lays down to eat, and has almost since she came to us. Do you think she would take to standing to eat?
DIY Hacks and How Tos 7 years ago
Good idea. Do you have any problems with your dog knocking it over?
kkoshar 7 years ago
Nope, these are really stable. The dogs are fed on a tile floor and the stands won't even slide around. (Each one weighs approximately 6 lbs.)
