Rangefinder for Garage Parking With Arduino
Intro: Rangefinder for Garage Parking With Arduino
This simple project will help you park your car in the garage by displaying the distance from objects in front of your car's bumper.
A 'Stop' message will tell you when it's time to stop.
The project is based on the usuals HC-SR04 or Parallax Ping))) (tm) ultrasonic rangefinders and an Arduino board.
I used the Leonardo but it should work on any other original or compatible board.
For the display I chose a matrix version for its size and for aesthetic reasons.
STEP 1: What You Need...
To build this project you need:
- An Arduino board:
An original or compatible board should work as the code doesn't make use of specialized pins/function.
You can find it everywhere on the internet or maybe you have one unused in a drawer in your lab. - An HC-SR04 or Parallax Ping))) ultrasonic rangefinder:
They are commonly used with Arduino projects so, probably, you already have it.
Anyway here are some links:
- Parallax Ping))) on Parallax
- HC-SR04 on Sparkfun
- Parallax Ping)) on Pololu
- HC-SR04 search result from Ebay - The Four matrix display:
I bought it from IOTMODULES on Ebay: 4 Way MAX7219 DOT MATRIX
In case the link doesn't work try contact them on their Ebay store. - Soldering skills, of course :)
STEP 2: Build the Project...
Download the arduinorangefinder.pdf schematic diagram.
You can find attached also the HC-SR04 pdf and the ping))) pdf, only for your reference.
The electronic diagram is very simple, follow it exactly.
I suggest to extend the wirings for the display and sensor of about 1 meter (see image1) so you can place them more easily later.
In the image2 you can see how to solder the power supply pins for the display and sensor: +5V from the display and Vcc from the sensor needs to be soldered togheter.
Every other pin must have its own terminal.
Image5 is the Ping))) version of the project.
Go to the next step when ready...
STEP 3: Arduino Code...
It's time to work on the Arduino side.
Download the attached MD_MAX72XX.zip library and install it from the IDE (sketch->import library).
Now unzip and load the MeasureDistanceV200.ino sketch and let's look into it.
There are several lines you can edit:
1) The Matrix display type:
the supplied library supports 4 matrix display type so it shuold work with most displays in the market. Just uncomment one define at a time and upload the code to Arduino to see if it match your display.
2) The sensor type:
uncomment only the line that match your sensor.
3) Choose your preferred measuring unit from centimeters or inches:
uncomment only the right one, a warning has been set in the conditional compilation, it will show you what you have chosen.
Now set the distances as you prefer, you can modify them later when the project will be in place.
Upload the code and check if all works.
If you get trouble please double check wirings and connections.
Update 2019/03/30 - The code has been updated:
> New matrix display library, it supports 4 display type (a lot of documentation inside the library)
Credits to majicdesigns
Update 2019/01/10 - The code has been updated:
> Added the possibility to choose the measuring unit from centimeters or inches
Update 2017/12/30 - The code has been updated:
> Turn off the display when standstill at STOP distance for more than 10 seconds!
STEP 4: The Project at Work...
Measure the height of the most prominent part of the bumper of your car from the floor.
Attach the sensor close to the wall, to the height you measured.
I used a polystyrene foam sheet in which I made a slot for the sensor (see image).
Now place the display so you can see it from your car.
Try to enter by car and check the distances, adjust them in the Arduino code and reupload it if need.
24 Comments
sblindheim 5 years ago
AppsByDavideV 5 years ago
Let me know if it works for you!
Have a nice day
\\Davide
Someone other reported this issue. I will implement this new (hope universal) library as soon as I'll have some free time (It's not my first job):
https://majicdesigns.github.io/MD_MAX72XX/
You can try it yourself if you want , it shouldn't be difficult.
The library supports 4 different matrix display type. (read the documentation on the site above)
Have a nice day!
\\Davide
I forgot to say that the above library comes with simple examples. You can try and see in few minutes if your display works correctly.
Let me know if you will do it before me :)
blitzgamingonline 6 years ago
DennisB36 5 years ago
Tutorial and code updated to show distance in centimeters or inches.
Follow the tutorial and choose the right #define in code
Bye
Davide
Now supports centimeters and inches.
Bye
Davide
denxmail 6 years ago
Hi,
Nice job! I just found this and realized that my project is quite the same. I added an ambient light sensor to detect the car (based on its light on) to activate/deactivate the display. Check my one here:
https://www.instructables.com/id/Garage-Parking-He...
Anyway your display is much better than mine - and a lot simpler. Great work!
AppsByDavideV 6 years ago
Thank you, i like your work too, The light sensor is a good idea :)
Hello Everyone!
The Arduino code has been updated, now the display turns off when standstill at STOP position for more than 10 seconds!
IvanJ60 6 years ago
great
how to turn off the display STOP when the car is parked after 5 minutes ??
When a car is not in the garage the display turns off and that's ok.
thank you
Hi,
i think it should be possible.
I will try when i will have some free time.
Stay tuned :)
ScottD172 6 years ago
HOW IN THE WORLD DID YOU FIND THAT LIBRARY?
Great work. Stupendous. I have been searching high and low for a library that can work with the 4 digits in a row. I did a nice scrolling clock but had to cut them apart and rotate them 90 degrees each. NOBODY seemed to have a library that could drive that 8x32 (4-module) unit. And they do not cut apart easily.
So EXCELLENT WORK!
Hi ScottD172,
thank you :)
But i must say this library is not mine. I just sligtly modified it for my needs.
Credits to:
Iotmodules https://github.com/iotmodules/fourMatrix
hs3xha 7 years ago
Thank you.
andhikategas 7 years ago
AppsByDavideV 7 years ago
Hi,
of couse you can use an LCD modifying the code. The goal of the matrix was to read it at an higher distance (few meters).
At this moment i haven't an LCD to develop the new code but it should be simple with a little of programming skill.
Just send the measure referring the LCD library and connect the LCD following examples on internet.
Bye
JoeP151 7 years ago
The wife NEEDS this!
