Rapidobe - a Cheap Way to Build Walls, Retaining Walls, Benches and Shelves
Intro: Rapidobe - a Cheap Way to Build Walls, Retaining Walls, Benches and Shelves
Rapidobe is a form of construction of our own devising. The idea comes from the simplicity of earthbags, but made faster, cheaper and easier. You can use any dirt, even if it has rocks in it, making it a great option for almost any terrain.
This method can be used for walls, for holding back dirt in an underground construction or retaining wall, even for benches and shelves.
For more detailed instructions, click here.
For more information about our other how-tos, visit our site www.velacreations.com
STEP 1: Foundation
For a foundation, dig a trench and fill with gravel or rubble. Its width needs to be wider by a few inches on either side than your wall will be. The fact that you do not need a concrete foundation is one of the reasons that makes this method so cheap.
STEP 2: Posts
Place posts every two or three feet on either side of your wall. You want the posts of one side of the wall to be directly opposite the posts on the other side of the wall. Make sure the posts are not leaning outwards. They can however lean in towards each other a little.
We have used metal pipes as posts as well as Juniper limbs. The advantage with the metal is that you can hammer them into the ground quickly. Tree limbs are much cheaper (in our case free), but you have to dig a hole for them. With short retaining walls that are only a couple of feet tall, you can use rebar - cheap and easy to pound into the ground.
STEP 3: Bond Beam
Tie a C-purlin or suitable bondbeam material to the outside line of posts [the first time we did this, we put the bond beam on the inside of the posts, and learned that the outside would have been better]. Tie it at each post. You can also use a self-tapping metal screw at each post to hold everything in place. It needs to be just above the top of the posts. Make sure that it is level.
The rafters of your roof will be attached to this bond beam.
STEP 4:
- Cut a fabric like hail screen or stucco mesh for the length of your wall. The width will want to be the sum of the height of the wall x2, its width, and an extra couple of feet, forming a U-shaped bag inside your posts. If you are doing a retaining wall, the bag only needs to be L-shaped. The hail screen will make the stucco easier.
- Place the hail screen inside the posts, with the extra couple of feet hanging down on the outside of the wall.
- Do the same with a vinyl tarp.
- With steel wire or other strong metal, tie the posts of one side of the wall to its counterpart in the other side of the wall, just below the bond beam. You can make the top of the wall thinner than the base if you wish.
- At the ends of the wall, fold the fabric in on itself, like the end of a package. Using wire, tie the end posts together along several points down the post. Allow for a bulge on the end of the wall so that the posts don't get pushed outwards. This will be sufficient to close the bag on the ends.
STEP 5: Fill
Using any dirt that is available to you, start filling the bag.
Make sure you tamp the dirt firmly every so often, so that it is well compacted.
Once you reach the top of the posts and have compacted that final layer, fold the excess of both fabrics over each other and tie them securely together.
STEP 6: Stucco
You will not need to stucco immediately, as the vinyl tarp is waterproof. However, it will eventually break down in the sun, so make sure you get around to before that happens. The vinyl should last at least six months in the sun.
On the inside, you can use any plaster, as it does not need to be waterproof. We use a gypsum plaster. This is cheap and easy. Just add water to the powder and apply with a trowel. You can then paint it.
On the outside, a concrete stucco is better. You want to use acrylic in your mix, as that will adhere far easier to the hail screen.
STEP 7: Buttresses
Depending on how tall the wall will be, you may want to add buttresses. These will help support the weight of the wall. You can make these buttresses into a feature, like a bench or archway for added beauty.
If you want to avoid the need for buttresses, you can make your wall curvy, which is much stronger than a straight wall. You can also make the wall shorter. To do this, you should build into a hill. Start off with a short wall on the ground, a few feet tall, and back fill with dirt. Then you start another wall a couple of feet back, and up the hill a little. This will give you a natural shelf inside the house.
12 Comments
travelfeet 10 years ago
Shouldn't the exterior plaster be more water/vapor permeable than the interior to prevent trapping moisture inside (if this method is used for a building)? The concrete stucco is more waterproof than gypsum plaster (not sure if this is still true though when its painted).
velacreations 10 years ago
wolf112 9 years ago
huskerland3 11 years ago
whait86 11 years ago
HickLife 11 years ago
petrox5 11 years ago
Broom 11 years ago
velacreations 11 years ago
nagutron 11 years ago
