Introduction: Raspberry Pi 2 Reset Button
This is a quick Instructable, showing how I added a reset button to my Raspberry Pi 2.
The Pi 2 has two hearder pin holes next to the display socket, which is marked "RUN". When this pins are shorted together, the Raspberry Pi 2 will reboot.
Step 1: Tactile Switch - B1719
I had a couple of these tactile switches, and decided to modify it slightly to fit the Raspberry Pi 2.
1 - Using long nose pliers, I first straightened each leg.
2 - Then, bend each leg as shown.
3 - Solder the tactile switch onto the Raspberry Pi 2.
Step 2: Reset Switch Fitted to Raspberry Pi 2
Solder the switch onto the Raspberry Pi 2.
Hope this was usefull.
Regards
4 Comments
7 years ago on Introduction
It is a brutal hard reboot though, so only use when it's got wedged -- unless you want corrupted files on the SD card :)
It will also wake-up a "sleeping" PI (that has been halted, yet is still powered) so you don't need to cut and reconnect the power.
Thanks MikeB. so I have learned over the weekend...
This is what happens if you give a Arduino guy a Raspberry :).
I am now using a shutdown button, and this "reset" switch is now only used to restart the Raspberry from a shutdown command.
perfect, I've put a button on my piB but wanted something similar for my pi2 :D Thanks
Glad you like this...
