Rasp Light
Intro: Rasp Light
I know there are lots of tutorials to make Ambilight with raspberry but none of them worked for me.
So I tried different steps of different manuals and I was able to make that work.
So let’s start by the parts:
- Raspberry pi 2 Model B
- Digitaler LED-strip WS2801 50 Leds RGB
Let’s talk about software for the raspberry pi.
I’ve tried Openelec and now I’m using OSMC, in openelec I couldn’t make the lights came on so I tried OSMC and everything work nice and smoothly.
STEP 1: Installing OSMC on Raspberry Pi 2
First you need to download OSMC
Now download the tool to put the image in the SD card. (Win32 Disk Imager)
Open Win32 -> Select the Device(SDCARD) -> Choose the image & click write.
Turn on the raspberry pi and complete the configurations.
STEP 2: The Next Step Is to Install Hyperion to Make the Lights Work.
- Preparing your system
Download OSMC updates
sudo apt-get update
Install OSMC updates
sudo apt-get upgrade
Install pre-requisite packages
sudo apt-get install git libqtcore4 libqtgui4 libqt4-network libusb-1.0-0 libprotobuf9 ca-certificates
- Installing Hyperion
Download Hyperion
wget -N https://raw.github.com/tvdzwan/hyperion/master/bin/install_hyperion.sh
Install hyperion
sudo sh ./install_hyperion.sh
- Enable GPIO's:
Enter this command:
sudo nano /boot/config.txt
Add this text to the end of the document, and then press Alt+O (Ctrl-O on Mac) to save, and Alt-X (Ctrl-X) to close, the document.
dtparam=spi=on
STEP 3: Connections
The LED strip has four wire connections.
- 5v, Clk, DI & GND.
We need to connect the 5Volts and Ground wires to an external power supply, they recommend at least 5V 2Amps.
The LED strip usually came whit 2 Ground(GND) wires because you need to connect the GND to raspberry to.
So the wiring connections are:
- CK(CLK) -> Raspberry Pin 23 (GPIO11)
- DI -> Raspberry Pin 19 (GPIO17)
- GND -> Raspberry Pin 20 (GND)
If some how doesn't work try to connect to the other end of the cable.
STEP 4: Final Product
Now you can arrange the led behind the TV. I put 16 leds on top and bottom and 9 leds on each side.
8 Comments
mbarky 8 years ago
Hi Speed_hack i tried all possible tries but not worked. i think it's Configuration Problem.
Can you please send me image from your Raspberry pi2 via "Win32 Disk Imager"
Open Win32 -> Select the Device(SDCARD) -> click Read.
Regards
Thank you :)
speed_hack 8 years ago
mbarky 8 years ago
Thank you Speed_hack. i already checked all the connections from the raspberry to the leds' and all of them are connected correctly and also to its Right end.
But when i disconnect the "Ground-Earth" from raspberry to the leds it works
is it important to connect it???
Thank you again :)
dtokez 8 years ago
I thought you had to use the config tool to set up the number of LEDs etc?
dtokez 8 years ago
cheers :)
acidmank 8 years ago
Has anyone tried this? Like dtokez says, how do you configure?
and these look like the leds: http://www.aliexpress.com/item/50pcs-WS2801-12mm-D...
