Raspberry PI Multiple I2C Devices
Intro: Raspberry PI Multiple I2C Devices
Frustrated because you can not use multiples of the same I2C devices in your project. No need to use slow multiplexers. The latest raspbian kernel support the creation of multiple I2C busses using GPIO pins. This solution is super fast.
STEP 1: Some Shell Comands
Connect one of your i2c devices while your raspberry pi is of, start your raspberry pi and run
sudo i2cdetect -y 1
You will see a table like in the attach figure. I have attach a BMP280 temp and barometric pressure sensor. The i2c address is 0x76 according to the table. Note this address.
Do this for all your i2c devices.
STEP 2: Case One: I2c Devices Have the Same Address
This was always the problematic case. An i2c bus can handle multiple devices, but they should have different i2c addresses. Some i2c devices have jumpers to set other i2c addresses, but many don't. In this case you may use a i2c multiplexer (hardware) to rotate the i2c SDA (Data) and SCL (Clock) or you can create an additional i2c bus or more.
I will create two aditional busses, nl bus 3 and 4
Open the cli and run
cd /boot
sudo nano config.txt
Add the following line of code, preferable in the section where spi and i2c is enabled.
dtoverlay=i2c-gpio,bus=4,i2c_gpio_delay_us=1,i2c_gpio_sda=23,i2c_gpio_scl=24
This line will create an aditional i2c bus (bus 4) on GPIO 23 as SDA and GPIO 24 as SCL (GPIO 23 and 24 is defaults)
Also add the following line to create i2c bus 3
dtoverlay=i2c-gpio,bus=3,i2c_gpio_delay_us=1,i2c_gpio_sda=17,i2c_gpio_scl=27
GPIO 17 will be the SDA and GPIO 27 will be the SCL for i2c bus 4.
Tipe control X to exit.
Note on the Bus Numbering and order:
Never use bus 0 and 2, it is use for other things in the board like eprom on hats etc
For the April 2019 raspbian release:
You should always start with the highest bus (Bus 4 in this case) in your config.txt and work through to the lowest bus (bus 3).
The lowest bus must always be bus 3
If you need 5 extra busses, the busses must bi in the order of 7,6, 5, 4, 3
This issue on bus order was not there when this Instructable was originally written. It seems like changes was made to the kernel.
Shut down your PI, switch it of. Connect your i2c devices to bus 4 (SDA to GPIO 23 and SCL to GPIO 24) and the other to i2c bus 3 (SDA to GPIO 17 and SCL to GPIO 27).
Switch on the pi.
Run:
sudo i2cdetect -l (Lower Case L)
You will now see that i2c bus 3 and 4 is also listed. Also run:
sudo i2cdetect -y 3
sudo i2cdetect -y 4
Now you can use your sensor in your programming language. Remember to specify the correct i2c busses.
Attach is an example for the popular BMP280 Temperature and Pressure sensor. No multiplexer can read 2 BMP280s this fast.
An example of 2 Sensirion SDP 810 sensors is also attach. Again working much faster than the multiplexer I used in the past
I created python code to read two new BMP388s from adafruit.
I may also add other sensors in future to https://github.com/JJSlabbert/Raspberry_PI_i2C_conficts
STEP 3: Case 2: Different I2c Addresses.
Simple. i2c is a bus. A bus purpouse is to communicate with multiple devices. Connect the devices parallel to the same i2c bus. You can use bus one.
Run:
sudo i2cdetect -y 1
You will see the devices listed.
25 Comments
Rodnee4 6 months ago
sarathkrishna01 2 years ago
captainavi 2 years ago
You do not need external pull-ups if you enable the internal pulls-ups just how the default i2c bus uses.
Add this line to your /boot/config.txt adding/replacing the pins you are using.
Add the line after the dtoverlay lines where you enable the buses.
# Change the pull on (input) pins 23 and 24
gpio=23,24=pu
After adding this the bus is not longer slow and works as expected.
https://www.raspberrypi.com/documentation/computer...
enrique023 5 years ago
Hello, excellent tutorial, very easy to follow.
I just have problems to find my other devices, when I write the command:
i2cdetect -l
in effect it shows me:
i2c-3 i2c i2c@3 I2C adapter
i2c-1 i2c bcm2835 I2C adapter I2C adapter
i2c-4 i2c i2c@4 I2C adapter
but when I write the commands:
sudo i2cdetect -y 3 or
sudo i2cdetect -y 4
they run very slowly and don't detect the devices (pressure sensors with same address).
I tried with BCM GPIO and WiringPi GPIO (23 and 24, 17 and 27) considering the possibility that I'm connecting on the wrong pins but It didn't work.
Any comment will be helpful,
JJ Slabbert 5 years ago
Tnx for feedback,
What pressure sensors are you using?
If you connect them to bus 1, do they show up when running i2cdetect -y 1.? If they do, try the following, read on.
The internal i2c bus (bus 1) has a 1.8 kohms pull up resister between 3volt pin and SDA, and also between 3volt and scl. Add those resisters between your 3volt and gpio pins used as SDA and SCL and test again.
Please let me know if this worked.
Also read https://www.raspberrypi.org/forums/viewtopic.php?t=64610
I beliefe that the bmp280 that i used had the pull ups on the sensor itself. My SDP810 (flow sensors) needed extra 10 kohms sensors, even on bus one.
allenz 2 years ago
ulfh2012 3 years ago
Looks like problem persist if I also have a DS3231 HW clock. After adding the lines for implementing multiple i2c-devices system refuse to boot
astromaphilli14 3 years ago
sudo
raspi-gpio set 23 pu
sudo
raspi-gpio set 24 pu
worked for me! SOLVED!
JJ Slabbert 3 years ago
sudo i2cdetect -l
sudo i2cdetect -y 4
Does it detect the devices on bus 4
CooperB12 3 years ago
jrbrearley 3 years ago
type: pip3 install adafruit-extended-bus
In your code, add:
from adafruit_extended_bus import ExtendedI2C as I2C
i2c_4 = I2C(4) # custom #4 per /boot/config.txt
ads40 = ADS.ADS1115(i2c_4, address=0x48)
ch4_48_0 = AnalogIn(ads40, ADS.P0)
And it works, can now read data from I2C-4 device.
dtoverlay=i2c-gpio,bus=4,i2c_gpio_delay_us=1,i2c_gpio_sda=17,i2c_gpio_scl=27
sudo i2cdetect -y 4 correctly show the attached ADS1115 at address 0x.48
However python adafruit_ads1x15 does not like i2c bus 4
import board, busio, time, traceback
import adafruit_ads1x15.ads1115 as ADS
from adafruit_ads1x15.analog_in import AnalogIn
i2c_1 = busio.I2C(board.SCL, board.SDA) # works OK
# i2c_4 = busio.I2C(scl=13, sda=11) # gets error
i2c_4 = busio.I2C(board.D13, board.D11) # gets error
Traceback (most recent call last):
File "ads1115_read_ch.py", line 8, in <module>
File "/home/pi/.local/lib/python3.7/site-packages/busio.py", line 31, in __init__
self.init(scl, sda, frequency)
File "/home/pi/.local/lib/python3.7/site-packages/busio.py", line 72, in init
(scl, sda), i2cPorts
ValueError: No Hardware I2C on (scl,sda)=(13, 11)
Valid I2C ports: ((3, 3, 2), (1, 3, 2), (0, 1, 0))
Any suggestions?
Marcmk 3 years ago
Next what I want to do is to publish it to my MQTT broker.
I'm stuck at that for a view hours.
StephenD148 4 years ago
JJ Slabbert 4 years ago
mquinteiro 5 years ago
dtoverlay=i2c-gpio,bus=3,i2c_gpio_sda=23,i2c_gpio_scl=24
dtoverlay=i2c-gpio,bus=4,i2c_gpio_sda=27,i2c_gpio_scl=22
I get two buses, but with the wrong number:
# i2cdetect -l
i2c-3 i2c i2c@4 I2C adapter
i2c-4 i2c i2c@3 I2C adapter
The buses are swapped!
One walkaround could by to get i2c@x data when open the device programmatically (I'm using C) to now which is the real 3 and 4.
(Note: I have found that I can check /sys/bus/i2c/devices/ but it is a bit tricky)
The same happened with me today after updating my OS
MureyT 5 years ago
