Introduction: Raspberry Pi + Openenergymonitor + PLC Panasonic With Python Via Ethernet
About: Share - Learn - Makers. Projects, Articles, #automation, #PLC, #Arduino, #IoT and More PDAControl
You want to connect a Panasonic PLC with Openenergymonitor monitoring platform, in this case using python embedded in a Rasberry Pi which has a web server which publishes Emoncms.
PLC Panasonic FPX C14 R
Voltage reading with AFPX module A21 (2 Input and 1 Output 4-20mA 0-10Vdc) PLC (Panasonic) FPX C14T, creating strategy and linearized voltage reading is done and sends it right through AFPX COM5 Communication module (1 port Ethernet 1 port RS232), Ethernet over TCP IP (general purpose) every second the value of the ADC is sent 0-10 vdc.
More info:
Blog PDAControl English
Blog PDAControl Español
Step 1: Operation..
The PLC is set to your cassette TCP Ip send the voltage value, a Python script from raspberry pi value makes the request and publishes in a dashboard Emoncms.
Materials
1 Raspberry pi
1 PLC Panasonic FPX C14R
1 Module Afpx - A21 module analog
1 Module Afpx - Com 5 module Ethernet
1 Multimeter unit
1 Supply 5 volts 2.4 amps Isolated (Rail Mounting)
1 TP-LINK TL-WN7200ND (Wifi - Usb)
Step 2: Testing...
